diy: how to buka front wira bumper??
extreem
18
johor
i hope cfu can help me la..how to open front wira bumper...standart one .i want do diy spray headlamp.
when i cabut skru headlamp the lamp can pull out.. it sangkut to my bumper.. now i want any one that know how to open it.
if can give me pic to open bumper....... i want spray headlamp ori wira to se ma.....
extreem
18
johor
tak kisah la...any one can help me.....not only cfu any one la
khguan
4,818
26
Seri Kembangan
fotopic.net
a forummer told me.. wira bumper got 2 main bracket/bone... u have to remove de bolts from below ur car then de whole bumper will come out together with de metal bracket... then u can remove de bumper from de bracket...
mivecmerah
799
i have done ur project...u can refer to the project "spray headlamp"
DIY session...
like this,unscrue at the center....a little bit hard,then unscrue beside(have to open/pull out)the signal....(i lost my signal at this stage)then u scrue out the screw there...then slowly pull out the headlamp...a little bit hard coz it stuck with the bumper,but do it slowly.. ;)
extreem
18
johor
i want the pic bumper
my bumper is not like wira biasa. wira 1999. it has like papan in the center bumper .i dont know how to open it.i was try to push headlamp out but my bumper rapat sangat and cannot out the lamp .i hope any body can send pic open bumper ..thanks
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Hello, :D
I don't know mine same as yours or not. Mine Satria 98. "A" portion of the bolts are behind the bumper. You have to remove the number plate then stretch your hand inside to open these. "B" portion is at the tire side. All of them 7 bolts together. Good luck! :D
ken12292703
1,542
5,138
SoMeWhErE
Did you mean the papan that holds the number plate?
The nuts are inside the bumper also. There are 2 nuts for each "papan". Remember to remove your number first. :D
extreem
18
johor
i must to open the flat no first ye.. blakang dia ade papan want to open to??????
WANNA ASK YOU YOU ALL GUYS SUGGESTION?
WHICH HID LIGHT IS BETTER?
" KAIER " OR " ISMART " ?
BECAUSE I HEARD THAT KAIER BRAND PRODUCE FROM CHINA SO I:burnout
