clutch questions
carlmc
75
1,508
guys,
tried searching but couldnt find the exact answer i want..
Do i need to change my clutch pump if i upgrade my clutch to Exedy 4 puck with the semi race cover? Using standard wira pump on Mivec Gearbox..
im having problem engaging the gears...
which part should i change? the bottom pump on the gearbox or main pump?
Pump from which car should i use? evo??
thanks...
LuKa
618
19
Kedah
if your pump is leaking then ull hv problem sfithing/cannot shift... if not... then why replace the pump.... maybe the problem is else where...
r u using the the whole set Racing Clutch+Racing Pressure plates??
calvin9683
1,768
171
3,163
JB
yeah, y change clutch pump if its not leaking???
do like wat bro skywalker suggest, bleed the clutch line 1st....
n also, u may wanna check if ur clutch level is too "low"??? if its too low, u may wanna adjust n make it higher...u may also wanna ensure u fully press the clutch everytime u shift...
carlmc
75
1,508
yes bro, im using the whole set...The thing is there is no leak whatsoever...level in the resovoir still at max...
---------- Post added at 10:21 PM ---------- 6 hour anti-bump limit - Previous post was at 10:17 PM ----------
already tried bleeding the line and adjusting the clutch higher..but after few days..back to the same problem..cant shift into gear(while engine running)...when i bleed the line again...after few days same thing happen again...no leakage...:hmmmm:
peterj
1,321
258
1,683
Kuching
wat power archived by your car? is it when the time u drive fast then cant shift in the gear? i experience on my mivec turbo since i use fullset 3 puck racing clutch,pressure plate and etc and i always go fast and furious, i think the clutch cant longer hold the power so the gear cant shift.... so i plan to switch to 4,5 or 6 puck.....
Dear all,
Please share your experience and comment after install Pipercam cam shaft.
My comment:-
I already install the piper cam in my car (Wira 1.5 SVDO) and use around 1 month. I feel the power is lag than before change to Pipercam when start run from 1K ~ 2.5K rpm. Isn't got any problem? Can you all help me to study the best degree (adjustable cam pulley) to be adjust to gain more power? The FC also become high a bit (before can run over than 550km per tank but now only can run...
