claying
KrisMas
434
175
1,543
It definitely is cuz clay won't leave anything behind that would cause water to bead....
eohl79
293
164
543
Bro droll, have you had a thought why the need to clay your car so many times? Sometimes over applying sealant/wax cause dirt to get trapped in more easily. Opti seal/OCW should go on thin, spread evenly and easily. Once cured it should give you some decent amount of protection before the need to clay again. Well i could be wrong, probably due to the environment that your car is in (parked in open, dirty/dusty, etc) or perhaps the paint itself (prone to oxidization, UV damage, etc).
Prevention is better than cure :nurse:
Veloc
3,234
991
Sabah
Wow DarkAccon use so kaw ah... I use about one cap (1 oz) to 500 mL water only... Even that is already more than their recommendation. But I guess it is okay to put extra. Just don't use overly dilute mixtures...
I gotta say man, claying is one of the most tiring job to do. Spray, glide left right left right until smooth, the rinse, then repeat, the fold the clay, then repeat repeat and repeat. Took me an hour to finish it on a myvi lol.
Droll, you clay your whole car after every wash or parts of it only? If whole car...man u've gotta participate in those marathon or iron man contest.
I find claying quite easy, or maybe your car is very dirty....:rolleyes:
droll
89
7
508
nolah, just that i like the after effect of claying. i find that washing doesn't completely clean the car. and this is partly due to the quality of water supply from our taps and i cannot satisfactorily keep a micro fibre cloth super duper clean no matter what i do. when i dry the car, i can still spot some dirt left (tiny little watermarks). with claying, i seem to have a lot less of that problem. that's why i was thinking of claying during each wash.
i park my car in the open air because my house doesn't have a covered porch. i have parked my previous rides before before in my house porch over the years and find that after a few months water marks will appear on the glass and it cannot be removed (except with something very acidic or by some intense scrubbing / sanding of the glass - but that's another story). after speaking with bro KC he said it is likely caused by rain water dripping down or splashing off from the roof, walls, etc of my house onto the car. i've spoken to another megiuars detailer before and he said the same thing. it's either from the house or tree sap (since no tree so must be house). that's why i park my car by the roadside outside my house.
so the car is super exposed to rain and sun. :(
But claying more for surface contaminants only, like rough surface that you can feel. Water marks better use polish to remove....
droll
89
7
508
yes, that is true but the water marks i'm talking about are not the permanent type. you know when you use a wet cloth to dry a window and after it dries you can still see dry water streak marks on the glass?
it's the same with the car body. so these are not the type of marks that need polishing to remove.
having said that, my car's paint is bad in need of a polish......lots of surface defects. this is the one thing i don't have time (or know how) to do. prefer to get someone else to do it. but difficult lah. most of the really good detailers that i know don't have a shop and they do it at your house. problem is my house doesn't have covered porch and they need one full day to do polishing. haih!
Okay, understand what you mean on those water marks. Then I think your paint have no protection at all. For me after every wash I top up the sealant protection.....
eohl79
293
164
543
Need to fix a gutter on your roof edge to channel the water somewhere. Also put on a coat of waterproofing layer before you paint your walls with weatherbond... :biggrin:
Do you use OCW regularly after every wash or so? Or is it plain opti-seal?
May i suggest you try other sealant/waxes instead. My opinion, opti seal is good and easy to use but does have its weakness too (don't want to elaborate, different people different criteria). Try other wax/sealants instead to see if it works better for you.
droll
89
7
508
yeah, i have to remember to do the waterproof coating for the walls but for roof tiles how?
i use zymol wax - not OCW even though i have a bottle of OCW. zymol is quite hard. i usually put optiseal first then zymol on top of it.
junbecks
29
6
1,503
just to share,
I have clayed a BMW 318 before (year 1995-1997).
It was repainted sometime in 2005 to purple and the bumper didnt have clearcoat.
I was claying the bumper and all of a sudden my white clay turned purple.
s1tl
1,237
1,019
713
Ipoh/KL
Since we're on the topic of claying - I wanna ask about using ONR as lube. I noticed that ONR will streak if it's left to dry on its on and according to the instructions it's best to wipe it dry as soon as possible. Does this mean then the process would be clay + ONR lube then dry?
Also what is your ONR mix proportions? 1 part to 3 parts water?
i clay all the cars i do with only water =.= ONR is overrated, and spraying ONR dillution for claying? =D try it with water then try it with ONR then u tell me whats different
---------- Post added at 05:39 PM ---------- 6 hour anti-bump limit - Previous post was at 05:38 PM ----------
just to share,
since u mention that the bumper had no clear coat on it, which means you are claying the paint off the body. stop doing that or u end up repainting it again
with water is more aggressive. ONR act as lube (slippery) so is sliding over and not taken as much contaminants as plain water itself....:biggrin:
KrisMas
434
175
1,543
s1tl, I would think you'd need something a little bit more lubricative (is there such a word?) than water for claying...maybe a few drops of shampoo (at the least) would suffice. The difference won't be on the result or how much contaminant was removed, but how much marring it leaves/creates. But, saying that, no such worries if you plan to do some polishing afterwards....*peace*
s1tl
1,237
1,019
713
Ipoh/KL
well, i clay right after i wash the car, does seem to leave any marring doesnt seem to be not sliperry?
MOTOCROSS, DRAG DOUBLE HEADER AT SEPANG THIS WEEKEND
Sepang International Circuit (SIC) race calendar for 2007 officially opens this weekend with the opening rounds of this year’s Sepang Drag Battle and the third edition of SIC-AAM Malaysian Motocross Championship; providing a double treat for local motor racing fans.
“It will be double the excitement, double the thrill at Sepang this weekend for racing fans. It is indeed an explosive start for 2007; and something...
