clarion vx-400a 2-din dvd/vcd/divx/cd/mp3/usb/bluetooth/24 bit player
clarion malaysia warranty
pls call ben 0162228108
location jin kelang lama batu 3
http://benhok.multiply.com
MONITOR SECTION Screen Size (W × H), mm 143 × 79 (6.5 inch)
Aspect Ratio 16:9 Display
Type Transmission type TN liquid crystal display Drive Principle TFT (thin-film transistor) active matrix display Number of Pixels 280,800 RCA Video Input 1.0 Vp-p (input impedance 75Ω) RCA Audio Input 130±60mVms (Input impedance 10kΩ or greater)
TUNER SECTION Frequency Bands FM: (MHz) 0.05 MHz steps 87.0 to 108 AM: (kHz) 9 kHz steps 531 to 1,629 DVD SECTION Useable Discs DVD VIDEO / DVD±R/RW Frequency Response (Hz) 20 to 20,000(0±3db)
Distortion (%) 0.05
CD SECTION S/N Ratio (dB) 1 kHz 80
Dynamic Range (dB) 1 kHz 80
Harmonic Distortion (%) 0.05
AUDIO SECTION Power Output (DIN45324, +B = 14.4 V) 4 × 20W
GENERAL Dimensions (W × H × D), mm 178 × 100 × 166 Weight (kg) 2.36
Power Consumption 3.3A (at 1W)
Power Requirement 14.4 V DC (10.8 ~ 15.6 V)
Speaker Impedance 4Ω (4Ω to 8Ω allowable)
A touch of innovation to seamlessly access your favourite entertainment
Superior iPod® and iPhone™ connectivity
USB connection* enables complete control of your iPod including video playback. Also “Works with iPhone” certified to bring its communication and entertainment capabilities into your car.
* To connect an iPod, please use the USB cable provided with your iPod.
* For video playback , optional CCA723 / CCA748 cable required.
* Please see our website for iPod models that can be connected.
Built-in Bluetooth® hands-free calling
With Bluetooth built-in, you can wirelessly connect your Bluetooth capable mobile phone to listen to calls through your car’s audio system. HFP/OPP/A2DP/AVRCP protocols are supported.
Rear USB WMA/MP3 file playback
The rear USB terminal supports WMA/MP3 file playback so you can connect a USB memory device and listen to music files that are stored on it. It’s an easy way to enjoy in your car the same music files you listen to on your PC or portable audio.
24-bit D/A converter for superb sound reproduction
The digital realm is made up of unnaturally square sound waves, as opposed to the smoothly undulating sound waves characteristic of the real-world environment. That is why Clarion’s 24-bit D/A (Digital-to-Analogue) converter over-samples the digital signal to recreate the natural nuances and expressions lost during the sound reproduction process.
Full range of connectors make it easy to upgrade and expand your system
6-channel / 2-volt RCA output with subwoofer control
With 3 sets of RCA outputs, you are free to add external power amplifiers to create a more powerful, sophisticated audio system. Also, independent volume control is enabled for the subwoofer so you can adjust the level of bass output to your liking at any time, regardless of the output level of the other channels.
2 AV AUX inputs / CCD input
VX400A is equipped with two RCA jacks for AV AUX input. In addition to being able to hookup an external video source for viewing in your car, the inputs also accept video signals from Clarion’s rear vision CCD camera which lets you see the area behind your car for safer driving and parking.
Distortion (%) 0.05
