Cheap tyre
6UE5t
6,000 RPM
6,756
1,300
You are quite right ! None of my tyres can last to 2 years !
There was once i bought a set of used Nexen 8000, has about 70% thread left, a return trip to Penang, i've managed to scrub the tyre down to almost 40% left. I wasn't driving very aggressive too. Probably this used tyre already has some thread problem so that's why it was gotten rid of.
Its amazing that i am still able to drive relatively quite stable on this thing.
Thanks,
Ken
What's the tread on those Nexen? Even so still suspicious that just trip to Penang will consume that much.
Mitevo7
1,456
179
3,163
Could not remember, but Nexen N8000 has a bad reputation for high wear rate. Probably has something to do with my negative toe out and negative from camber setup at the front alignment. I sped at about 195 km/h quite steadily and took bends at about 160 km/h (GPS Speed).
Probably that's why the wear is so fast ?
Nexen N8000 have 4 large straight grooves, less rubber, good for anti aquaplaning....
6UE5t
6,000 RPM
6,756
1,300
Looks like combination of all those but still 30% drop in tread with just about 800+km is too much. I suspect the miss alignment is the biggest factor.
Mitevo7
1,456
179
3,163
Well my front toe settings were intentional, to have better corner entry. It isn't much, just about 0.3 toe out, rear was 0.3 toe in. This settings are abit twitchy but good if you know how to control the car. Furthermore, i intentional running wider front track than rear by 5mm each side, the car is slightly oversteer but nothing unmanageable, to add on the rear of the car is using 24mm ARB, front is stock 19mm, need stiffer front ARB to balance out the steering.
Thanks,
Ken
6UE5t
6,000 RPM
6,756
1,300
Thanks,
Ken
Thanks,
Ken
Only 5mm wider, how could that be? Minimum is 1 cm wider tires right?
Mitevo7
1,456
179
3,163
I'd customed front spacer 22 mm to clear my BBK, rear 25 mm to induce a bit understeer since Lancer has the tendency to snap oversteer when switching left and right and quick motions. My front track measures 1573mm, 1578.5 at the rear. The rear is upgraded with stiffer ARB, hence the car likes to oversteer alot, its a lot fun if i am driving alone. I am looking to upgrade the front as well so that the movement can be controlled properly.
Thanks,
Ken
Han_neversolo
Aug 10, 2018
18
Anyone tried Toyo Proxes TR1? I am looking to upgrade my tyres (currently using Turanza er33). Still deciding between TR1 and Hankook v12 evo2. Both almost similar price. But can't find any comparison between these 2 tyres.
6UE5t
6,000 RPM
6,756
1,300
TR1 still very new. I'd pick V12E2 coz Toyo usually is not so good and the tread wear is much lower so won't last as long.
  • Like
Reactions: Han_neversolo
Yah, Hankook now listed under premium tyre in UK tyre website. Toyo still in mid range together with Yokohama, Nitto, Falken, Nexen, Maxxis etc.
V12Evo2 proven, TR1 still new, unless you want to be guinea pig and give us your reviews......
Han_neversolo
Aug 10, 2018
18
I see. I thought of trying the tyre, since none of my friends tried it before, and TR1 does offer my current tyre setup, which is 195/55/R16. If I go for v12e2, I will need to change to 205/45, which I not sure whether it is make the ride better or worse. Both ways also will be an experiment.
I also thought of Conti UC6, TyreReviews rating seems not bad also, despite it is touring tyres instead of budget UHP tyres.
6UE5t
6,000 RPM
6,756
1,300
Then try the TR1, it should be much more comfortable at that size. Forget about UC6, it's crap tires! Even my friend who doesn't know much about cars and drive normal on his uncle-ish 2.0 bone stock Camry still can comment that it's not a good tire and regrets buying it!
  • Like
Han_neversolo
Aug 10, 2018
18
Alright, thanks for the advice :beer:
Yup, agree with bro. 6UE5t, better try TR1 with correct tyre size rather then experiment with different size. UC6 touring tyres different category from UHP already.....
  • Like
hi all,
i facing this weird problem. i have an apexi turbo installed for the last 2 years and it was working fine.
until this week, the timer function most of the time was not working anymore. when i off the car, the timer's screen go to the timer section and it off before the count down start >.<
i have redo all the connection but it still having the same problem...weird case it do work once in a blue moon (1%). fyi, i also ground the grey wire (connect to handbrake) so that the...
