hi, i recently had a CEL for o2 sensor. i used to be getting around 450km on a full tank. after changing the sensor, i could only get about 300+ . later i found out that the sensor was from a different engine.so i managed to get a proper one and thought it would be fine after that. but i could still only go 300+. i know i was running rich during that time coz the plugs showed so, but even after dyno and setting the A/F properly, its still the same. ive checked almost everything else and dont know what else to do. plugs are fine now, no leaks, etc.
the only thing i suspect left now is whether the o2 sensor that i changed could still be faulty. not showing a CEL, but maybe its running in open loop all the time. how do i find out for sure? also, with a piggyback, at what point does the o2 sensor switch from closed loop to open loop?
please help
thanks.
please help
thanks.
