Brake Hose Bracket
scudracer
123
Stanley ... notice those brackets welded in to the damper bodies? This is where the brake hose normally mounts, and is held in with a clip.
A lot of aftermarket stuff doesn't take this into account. How about your Titans?
I had a bad experience once when I 'DOWNGRADED' to braided stainless steel covered teflon/nylon lines, and the cable ties they used to hold it onto the damper bracket came loose. The line then rubbed against my wheel until it burst open, and I lost my brakes and had to drive home slowly using the handbrake only, late at night to avoid traffic.
As the suspension and braking system are safety items, right down to the balljoints (you wouldn't want your suspension to collapse on the road right? I've seen it happen quite a few times!), these are important issues to look at. Even many of the 'big name' brands don't look into this as perhaps for track use, its OK but road use puts a lot of strain on all parts of the car.
slk850
885
Originally posted by ninja_iga@Nov 25 2004, 02:01
see the bottom of the pic..
Hey, stanley.....is it this set of titan on my ride now ? :lol: :lol:
the engine off timer wire is connect to ignition switch & handbrake switch, how about the o2 & a/f, is it connect near to the ecu??? it will hv some problem or not??? and how about voltage connect to which wire???
