barke problem
SE86
299
474
1,563
hey all sifu..i have a wira 1.5 manual...after i change my brake master pump to a the GSR wan the brakes are less efficien..wat should i do???any idea?izzzit because the pump to big or wat???my current converison is rear disc brake and steel braided barke host...on highway the car cant brake properly...any idea how to overcome???thanks in advance
g88
3,082
54
5,148
did you bleed/flush all the brake fluid ?
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
when u install new/another brake pump, it is better to flush or change the brake fluid to avoid bubbles trapped inside the brake fluid...
what do u mean by cant brake properly??.. doesnt grip??... spongy??... vibrates??... different feel, different problem wor...
SE86
299
474
1,563
erm bro..the brakes i change to DOT4 oil also..bleed all the four tires..feels like doesnot have grip when brake...and vibrates...how???
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
skim disc.... diy braided brake hose...
if no more vibrations, but still no grip, time got better performance brake pads...
SE86
299
474
1,563
ok..got it...i already using steel braided brake hose...pro-rs brand...i think will change to bigger rotor and see.....
A Post Every 5 Mins
im using the aftermarket headlamp for my honda.....the problem now is with it fuse....this problem didnt occur last time....the fuse code for the headlamp is 15.the fuse got "burn" last two days....so i replace it with the same fuse code that is 15.when i swicth on my headlamp the lamp didnt turn on....so i check back the fuse...and the fuse already"burn".is there any wiring problem fo my car???or i just have to use other fuse code???i mean the fuse that can hold a bigger electric...
