B16a White Face SpeedoMeter Issue
Eg Rocks
591
Hi All B16a Kaki Here,Recently I Drive My Car To KL To Makan Angin:driver:
All The Way PrangPrangPrang 180-200++ Damn Shiok Sia:top: Play With sg subaru Some More Hahaha But Yesterday After Work Drive Back Home I Elak Satu Lobang Besar Pehhhhhh Tak Lepas Aduihhhh:banghead: Meter Terus Lompat Pergi 180+++ Than I Try To Hit The Dashboard It Back To Normal Awhile But This Morning Still Back To The Same Again:boring:In The Noon Time Take It Out To Service Clean It Than Put Back Still Cant Slove It....Any Shop Got Sell 2nd Speedo Meter Or Parts?Can It Still Repair Back???Or SparePart Shop Got Sell The SpeedoMotor For Replacement??
Please Advice
Thanks:proud::biggrin:
aalto
406
93
3,028
First, check if its your speed sensor that has gone crazy...
If Ok,
you can take out the speedmeter(4 screws behind the cluster) & check the copper wire connection behind the meter...(very halus cable)...if snapped, need to solder back..
spoon civic
403
36
528
terengganu
maybe your speed sensor not ok... socket kaki or sensor wire putus lorr....pls check that first..if still ok..then must check your speedo meter.....
Unsacred8002
102
12
518
Cat City
Common problem for EG actually. Doesn't matter d white 1 or d black 1. Check ur VSS. Should be located on d top of ur Gearbox. If change VSS also d same, then its d speedometer prob. I already used 2 EG6 meter set.
WAH IDRIS CUTS A DIFFERENT TUNE FOR FORMULA ONE
Describing it as the new ‘trademark of Malaysia’s Formula One’, musician Datuk Wah Idris believed his newly produced GP Soundtrack would serve as a two-pronged tool to promote the F1 Petronas Malaysian Grand Prix and to further enhance Malaysia’s prominence in the eyes of the world.
“I always believe that music has the strange power in driving a message effectively. This is what this GP Soundtrack is all about – delivering a message about...
