Atessa stop functioning after changed clutch n transfer case oil
kanan
Attessa stop functioning after changed clutch n transfer case - R32oil
Dear fellow skyliners, my atessa works like a charm before doing some maintenance on the transmission. Things that i did
Changed clutch
Gb oil,lsd oil, transfer case oil(atf matic d)
Lock hicas
After cmg out of the workshop, the 4wd lights up. The front torque meter no longer responding. Mech said that during flowing out the atf oil, it was black n smell burning. Appreciate your all views on this . Why my 4wd suddenly stop functioning. I checked that the reservoir bottle at the right back bonet side also below min level.
No more syiok without 4wd :banghead:
what brand of oil u changed?
4wd still got i guess...just that the traction/yaw control thing not functioning properly....maybe,
must ask the skyline guru here.....:)
The pomen used Castrol CVTS in the transfer case. I thought he is gonna use Nissan Matic D oil. are they the same? :smokin:
From manual Hydraulic control Attessa use Nissan special power steering fluid
Transfer case Nissan matic fluid D
Changed clutch
Lock hicas
You may want to fill up the reservoir just slightly above the full-line. Check if during the bleed process if you have vent any air trapped in the transfer case bleed nipple, and well as the bleed nipple on the atessa pump at bottom right rear.
your 4wd still functioning only traction/yaw prob....drain th oil put matic D (dextron 3)...then check again where do you send your car? The car was normal before this right? logically there must be something wrong with the oil type or oil level...did you leave your car without supervision?
If im not mistaken cvt oils are thicker causing transmission without cvvt to overheat if you use them( correct me if im wrong)
As per eyong suggested, fill it up first and if the 4wd light is still on : for r32 - go and take a look at the attessa control unit. It should have a led flashing error code. For r33 and r34 - follow these instruction https://sites.google.com/site/tyndago/gt-rattesainfrormation Once you know what is the error than you know where is your problem and what need to be look at.
FYI if 4wd came on thats mean your the car is in 2wd mode all the time. And yes its sucks to have a gtr and running 2wd all the time :banghead:
And for the oil, any power steering or atf fluid (dextron III equivalent) will do.
Shark79: Before this it working normally.
Send back the car to the workshop. suspected the wet clutch plate has worn out since during the transfer case oil change since the oil was really black and smelt like burnt clutch. Currently we think that when changed the new oil which is thinner than the drained one, the clutch is slipping which causing the 4WD lights to come out. Changing the plates..And the reserve tank/bottle at the right side of the back bonet is for the clutch pump hydraulic lines the mech said. (which i think it's absurd, it should be the atessa 4wd hydraulic reserve tank). the clutch pump reserve tank is at the front engine bay near the master pump. :hmmmm:
Who is your mech ? There are some of us in here go to a particular mech...pm me if you are interested
Here is the error code. I read 18 & 22
Attessa R32 - YouTube
18 for ETS pressure switch or circuit
22 for ETS oil level switch or circuit
I hope this is just because of the empty reserve tank and bleeding work that the mech didn't do initially.
u sure the wiring is good for the sensors?
The wiring i think ok. Before this all working normal just the cigerett lighter not working
Btw the car now ok already after the mech did air bleeding properly on the attessa hydraulic system. How much different between cvts castrol oil with the power steering oil? Bcoz instead of using the power steering oil, he used cvts oil in the hydraulic line :banghead:
