allo..allo..need help here (honda)
myupgrade
106
dear zthorianss..
i hav a prob with my car..FYI, my car is b20 with type R ecu+vafc at 45% correction..my problem is..my O2 sensor (or exhaust sensor) maybe malfunctioned. My car gives engine sensor problem signal when i maintain certain speed.lets say i maintain 70km/hr at same gear..the signal will flash and my car will loss some power+jerking
i made a check with various w'shop..all request that the sensor must be replaced. i also sent my car to honda service centre and the mechanic said my car maybe have problem with knock sensor..the symptom (car jerking) is knock sensor problem, and O2 sensor got nothing to do with thiss (altough check with computer the o2 sensor gave the problem signal)..o2 sensor is more to calculate the air (so2+co+co2) out and does nothing with the jerking..
i have reset the code error and replaced with other half cuts one..but the problem still the same...
is this true?i am not sure why when i maintain the speed (not accelerating) the car gave the signal and jerk all of a sudden..my car have history of jerking prob..
is wiring got to do with this?bcoz signal is out but the car jerks..or maybe related to vafc?i dont think so...
please help.im bored to drive b20 with car jerking prob...thank youuuuu..
woodykids
271
cheras
Remove the vafc and type R ecu and replace back the original ecu. This is 1 of the solution to solve the problem
Dino@Casper
666
P.J
If your o2 sensor is faulty you will face problem, simple enough reasoning the ECU doesn't know how much to fuel to compensate, might give 2 much or might give 2 little.. When its lean it will knock n u will feel the jerking..
Hi guys, would like to know more on how to mod my perodua viva. I know its a small car and you may be thinking why would I want to speed in a car like this. Well, basically I love modding cars. I want to take this as a learning process. So far these are the mods I have done:
1. Full exhaust system. 3-1 stainless steel extractor, 1.6" piping, bullet and s-flow muffler with exhaust tip.
2. AXT Cross drilled slotted disc rotor (OEM Size)
3. Ctech Front 2p Bar, 4p Front Lower Bar, Rear...
