Airtrek turbo idle problem
Apr 21, 2015
hong kong
Hello Everyone,
i would like to adjust the idle a bit for my airtrek turbo cu2w. can anyone tell me where to adjust it? that would be great if someone can show me a photo. Thank you very much.
Best regards
4gbanger
1,958
386
1,683
Johor/ShahAlam
im not sure but last time my mechanic adjust the idle from below the throttle body.. but it wont increase much if your Idle control valve is malfunction.
Airtrekcarmod
hong kong
+++++Thank you for your quick reply! it might be Idle control valve problem. However, i just want to try to adjust it and then test it before a further repairing. So that i would like to know the exact place the adjust it. Thank you
Idling controlled by idle control valve you cannot adjust manually unlike our old school old engine....:biggrin:
Is the TPS Sensor for Mitsubishi 4G18 engine can be buy separately , cause mine went kaput , hesitation on certain degree of throttle,unstable idle sometime as low as 400rpm sometime as high as 1100rpm & drink fuel like thr is no tomorrow , I check the sensor by using multimeter and found out sometime there is a loss of continuity on certain degree of throttle opening & asked a SpareParts shop regarding this sensor , they say it come as a whole throttle assembly including the IACV Stepper...
