Air box good ? or hks suction kits good?
alvinT
222
i believe both of it are the same...as they are doing the same job as higher air flow into engine...
DarkChild
1,449
674
Apexi offer the cleanest filtration while still allowing a good flow of air in to the the engine. I think it's personal preference. If you go for a less restrictive air filter, but doesn't filter the dust from the air as much, just make sure you change your oil regularly. Just my opinion though... :biggrin:
gobiz
926
29
3,028
A lot of people think ARC airbox is the best.
lkeong88
394
121
1,543
Cheras
But the results are from 10 years+ ago, and HKS has revised their sponge few times and alot of imitation apexi in the market
veilsideboyz
1,616
17
Get a K&n or stock air box filter more good !!
I'm using Trust Air filter...but always suck hot air !!
If using open port filter , better make a aluminium heat shield for it ~
Azu MET008
237
32
My Vote go to Air Box.
I think car should deserve cold air from outside.:rolleyes:
gobiz
926
29
3,028
Yes, seems to be the reason why quite a few people are buying up the ARC air boxes. It also looks HOT (to quote Paris Hilton).
The only trouble is it doesn't seem to fit with hardpipe kits.
DarkChild
1,449
674
That 's true. It's a very old test. Even so, I don't think there will be such a drastic improvement for the HKS sponges. It faired the worst in that test. Even with the improvements, I doubt it will be better than the apexi. That being said, I am still using the HKS pods. Came with the hard pipe kit so why waste it. =P
Yeah, there are many many imitation products in the market nowdays. There's this 'paria' company using Mine's name on their products. WTF! :thefinger:
---------- Post added at 10:13 PM ---------- 6 hour anti-bump limit - Previous post was at 10:11 PM ----------
Yup. Not to mention if you change your bonnet, occasionally there will be some fitment issues.
mizunori77
1,387
1,041
am using the HKS suction kit. too bad that its hard to find a genuine hks sponge though :banghead:
MrNismo
591
65
5,028
The HKS sponge is good, but make sure you get the 3-layer dry type for our dusty environment, and beware, it's only available in green. Used to have a 2-layer wet type and left lots of chips on my compressor blades.
farizio
482
37
no filter makes the best engine sounds
sugizo_takuro
71
10
1,508
i use the k&n imititation..after use it, feel lots of difference in response and pickup and also the grunt :top:.. if u want to use the original airbox, use drop in airfilters and custom made CAI into your airbox.. fresh air direct to your airbox are better
a31gtst
507
Has anyone tried AEM filters?
http://www.aemintakes.com/dryflow_air_filters.htm
cmng
3,290
72
using it
err no idea since i one shot all change so no idea got improvement or not la
but washable la
omaroDDin
263
i think the points put forward at 'the clipping point' makes the desicion very easy. cone suctions are much better than mushroom heads. apexi seems to be the best with k & n coming in close at second.
Britain's Project Kahn will debut their second Mercedes SLR McLaren. Packed with a new body and Kahn RS-X wheels shod in 20 inch performance tires in front and 21s in the rear, replacing the original 18-inch combination.
The supercharged 5.4 liter V8 pumps 677bhp, a 60bhp increase over the original engine. Suspension has been lowered and an addition of a performance exhaust...
