KryPToN said:hehe.. experince the same problem with u man. putra or gti?? depends... answer these few questions and it will probably help...
which look you prefer.. sedan 2 door(putra) or hatchback 2 door(gti)
do you need boot space? yes(putra) or no(gti)
important for ppl going for crazy ICE equipment
are you willing to spend more on your car... yes(putra) or no(gti)
(to get a putra to drive like a gti... need to spend some $$$ to do up the handling of a putra... plus if u wanna go for engine mods... then both also need to spend hell alot)
you like red(gti) or black(putra) on your engine? probably not important.. gti engine cover (or whatever its called) is red while putra is black...everything else is the same.... correct me if im wrong)
you need to ferry many ppl often? yes or no
(if yes... get a 4 door la :) but the putra rear seating leg space is a little bit bigger then the gti... not much but believe me... ur frens wont complain so much)
thats all the few questions i can think of now... other then this i think no difference between the gti n putra... i ended up with a gti...
hope this helps... happy buying man~
yea..the back space for gti is kinda small..i've never sat on the back of my gti b4 but according to my frens,its suffering.. hahah..get a putra..much nicer look ;)KryPToN said:hehe.. experince the same problem with u man. putra or gti?? depends... answer these few questions and it will probably help...
airflow sensor or throttle sensor ... something doing wif fuel injection ...wchuan54 said:I am driving a 1998 all original Putra-manual, recently my putra seem like 'lack of power', it 'jerk' when i accelerate, i think one of my cylinder is not working properly or i need to check my spark plug?? any advice? may i ask the Putra driver what is your RPM reading when you stop the car? mine is below 1000, is that normal?
Happened to me before. Check your spark plugs. Otherwise, test with different cables.wchuan54 said:I am driving a 1998 all original Putra-manual, recently my putra seem like 'lack of power', it 'jerk' when i accelerate, i think one of my cylinder is not working properly or i need to check my spark plug?? any advice? may i ask the Putra driver what is your RPM reading when you stop the car? mine is below 1000, is that normal?
