Adjustable Fuel regulator
navz
102
Ipoh
Hi,i would like to ask about below video..i dont know how this happen..at first the hose from fuel rail to my fuel regulator got leaking.and i replace a new 1 and then i found my adj fuel regulator reading become weard,it suppose to increase not decreasing when i press the throttle adoyai.. pls view and let me know what causing it...thx sry for my bad english..
YouTube - viva fuel pressure dropping
navz
102
Ipoh
sry for newbie question..how do i detect which problem that im facing..lets say fpr vacuum?cuz fuel pump abit hard to change and to test it problem or not..
navz
102
Ipoh
thx bro..now i know what to do..
mahfudz_mn
181
21
Bukit Jalil
i think the pressure gauge is reading right
from fluid mechanics class; changing from static to flowing condition i do expect the pressure head to decrease as some of it is being converted into velocity head, and the gauge only reads pressure head and not the velocity head like a pitot tube
all these info is right, given that the fuel pump is at constant output...
xtremeleo
3,247
464
the thing is, the regulator is supposed to retain the fuel pressure from dropping, hence there are sumthing wrong in his application. the vacuum on top of the fpr is supposed to help in increasing the pressure with manifold pressure, he is using a rising rate fpr fyi. the reading is supposed to rise with the revv / manifold pressure
navz
102
Ipoh
yup..it usually raise from 2.5 to 3.5..but now..it happen to be 2.8 decrease to 2.4 ....and i never touch then adjuster..going to the shop where i bought fpr n ask them whats wrong although i already know 2 posibility problem..thx again guys.
xtremeleo
3,247
464
no problemo sir, of course they are other possibilities dat gives out dat problem. report back if the problem still persist sir
navz
102
Ipoh
okay...thx again
hi all...
i need some advice from u ppl out there regarding my turbine..
i'm using b6 turbo...everytime my turbo ons, which means the boost meter goes more than 0.1, white smoke will be coming out from my exhaust...its pretty alot at times...i duno whether my turbine oil seal has any prob or is it my turbine itself...but then the power of the car remains the same...
plz assist me on this...tq..
