H22AR on CL1 - drive below 100 kmh or 3000 rpm, full tank of 60L can give you around 700km before fuel light on. Vtec on 10% . But normally very hard to keep it up.
H22A on SV4/CD6 - Donno.
CL1 = manual lah bro.60L around 700km is in auto or manual?
Pls advise.. Thanks
CL1 auto la brother. (just repeat what bien said).60L around 700km is in auto or manual?
Pls advise.. Thanks
Lebih kurang lah tu, and as long as the rpm meter is below 5.5k vtec point.Aja, if im not mistaken, in 5th, the RPM at 170 is still under 5k rpm. because in 4th can hit the 180 km/h limiter.
160km/h is much moire saving, at the same time, nice cruising speed. Still can follow E60/E90 W211/W204
aja, u prepare the approval paper....then i'll sign.....hehehehehehehe......Lebih kurang lah tu, and as long as the rpm meter is below 5.5k vtec point.
I think PDRM should put the speed limit at hiway at 160kmh(before vtec bukak).
Not yet bang. I met him during the weekend, nak gostan a bit susah. He now drive up to 4th gear only. 5th will grind. His car demn chun sial. Carbon hood, buddy club racing spec damper, modulo spoiler.aja, u prepare the approval paper....then i'll sign.....hehehehehehehe......
Bump: bein san, zaim car ok doh ke?????
Local SV4 F20/F22 engine?....thirsty engine.bien,
I read a post from u at motor trader.
u did mentioned that local SV4 stock engine have same torque with H22A.
can u pls share more on local SV4 engine spec?
Pls advise.. Thanks.
I mustve mistaken then.bien,
vroommm, vrooommmmmprangprangprang pranggggggggg, pranggggggggggggggg, prangggggggggggggggggg wooo hoooooif you dont find an AUTHENTIC CL1 (hehehehehe), you can always settle for the car that spawned the CL1 EuroR, the CF4 SiR-T.
manual LSD, 200PS F20B. extremely addictive VTEC bark.
Fairy-chwan drives a CF4 with an SiR-T motor. stimmm
dear bro.. had my ex wife cd6 h22a manual and now with a accord touring neo sir-t... both cars tapaued the Perdana 6A12TT, 6A12 NA and 6A12 mivec... had a run with a perdana with a single big turbo twice... launching he can cucuk me at 3rd gear, once i go 4th i can start to pull away... heheheAny H22A user tested with Perdana 6A12TT, 6A12 NA and 6A12 mivec?
