A/F ratio and Voltage
DC!
215
Jzeh-Bee
hi all,
i'm driving 1.8gsr.. i have an apexi pen timer in my car, the reading of AFR is 20.0 (blinking) and most of the time the voltage reading is below 13.0 while cruising (ard 12.5 ~ 12.9).. my battery just replaced last 3 mths..
any idea whr goes wrong and wat to chk?
thanks..
DC!
Cheong Mou Kei 4G9XT
580
Ampang
www.geocities.com
well...if u have new batery n good grounding cables....there is no reason yo voltage is 13v for a GSR
unless.....yo alternator is weak...maybe it is time to replace it...
manual GSR comes wt 75amp alternaotr while auto is 90amp...
normally ppl go for 90amp if thier 75amp is kong
normal valtage for cold start up will be around 14.1v n when in normal operating tempeture is around 13.6v +/- 0.2v without aircond turn on.
Danny101
464
and above all that i suspect something is wrong with ur timer coz under normal situation if ur afr is around 20 ur engine should be kaboom by then........cheers :rolleyes:
guys ...need some confirmation from you all...driving 1.3 efi satria
intend to rev my car from :
1.1st gear 50kmh
2.2nd gear 80kmh
3.3rd gear 120 kmh
4.4th gear 125 - 130 kmh
5.5th gear ..still maintain 125 - 130 kmh
sometimes when i slowly drive from 1st gear to 2nd gear also will face some slipping problem ...
but not always ...
so from the statement above ...the 5th gear am i facing a a clutch slip probleM ? thats why my top speed cannot go any further ?
