Hello all, Since Raya long holiday coming and many will be traveling home or going or a holiday. Here are some 10 important things to self check to ensure a safe journey for your family.
I compiled a list and attached pictures (Not mine) from the internet.
1) TIRE Threads
Check Threads. Ensure they are not bald. If they are <50% it will not be as effective on rainy days on the highway. Do drive safe or best, get them changed.
look out for signs like this... if there are any abnormal wear, please get the tires changed.
2) Check TIRE Pressure.
Most cars have recommended tire pressure chart on the Driver side door panel. Use that as a guide.
3) Engine Oil + Other Fluids
Check the levels. While at it, look at the colour. If its dark and sticky, time to change.
Top up all Fluids (And check them)
Battery Fluid (If it is not maintenance free or Dry Cell)
Radiator (Add coolant)
Window Washer Liquid
Brake Fluid
Power Steering Fluid
Other fluid : AYC, Methanol, NOS... if you have them...
4) Check Lights
Turn on your headlamp, hazzard lights, turn signal. Get a friend/family to step on the brake while you walk around to make sure all lights are functioning
5) Fan, Alternator, Timing Belt
Do an eye-ball check on these belts.. Just look out for signs of cracks or wear on the sides of the belt
Simple DIY checking will ensure better peace of mind during these festive season's traveling.
To all Muslim Friends : SELAMAT HARI RAYA AIDILFITRI
To all other Friends : HAPPY HOLIDAY
and to everyone : Be Safe On The Road, Have Fun!!!
1) TIRE Threads
Brake Fluid
4) Check Lights
