[H] [K] [S];4252861 said:Aiyak! Keta kuat got prob meh?!
LOLZ! Bro, keta gua masih dara la.. mane la kuat bang oi?!? You monstar baru can consider KUAT cam tongkat Ali! LOLZ! Respect!
---------- Post added at 03:44 AM ---------- 6 hour anti-bump limit - Previous post was at 03:39 AM ----------
1) White Smoke
I'm guessing that when u say "Step on it", it is >5k rpm...
if that's the case, then most likely turbo needs an overhaul.
I heard there is a good place in KL (i think it is called Mat Turbo) to fix it. Check this forums.
If not, i think i have a downloaded pdf DIY for the 4g93 turbo unit.
2) Tappet
Yea, mine too. If the engine oil is too low, the tappets start to sound (good warning system yea!!!)
3) Jerkiness
Mine had that same problem, especially when I rev past 3.5k rpm
Problem solved after I changed my spark plugs to Iridium IK22.
Bro!! Thanks for the info. Will let Tong Turbo check out my turbo unit soon. And changing me spark plugs too. Any solution for those noise tappets? This is one warning system I can live without! LOLZ!
![Biggrin :biggrin: :biggrin:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/biggrin.gif)
