Need inputs for reliable and not too expensive workshops/foreman for 20V 4AGE
Need to have some work done
1. need to check AE92 long meter VSS sensor not working getting error code 42 so I get the check engine light
2. Need help to install and wire oil pressure sensor. I have this and need it installed and wired. No need to wire the oil temp for now. I just need the oil pressure sensor on the meter working
3. Need to check speedo meter not working (maybe need to change cable or verify if speedo meter is broken)
4. Need to check gear oil leak (not that bad yet but its bothering me)
5. Need to install aluminum radiator (the one im using is leaking now)
6. Need to check timing
7. Do full service (oil change, filter change, gear oil change, spark plug change)
8. Install double layer brake servo
If you can recommend one stop shop to do all it would be best instead of moving from one shop to another.
My location is Cyberjaya. Don't mind going Shah Alam, Seri Kembangan, Kajang, Puchong, PJ or other areas nearby as long as shop is reliable and price not that expensive
If possible open on Sundays. Thank ZTH
