TEMP prob
milo87
79
2
1,508
hello and good morning... i would like to ask... my car got temp prob... usually temp meter shown around 1/4 of the full scale... but last 2 days... my temp rising more than 3/4 of the meter... hurm..
What the problem that i encountered? how to solve? izzit water pump prob?
milo87
79
2
1,508
owh... but my rad just using it for 6 month only.. rad 3 layer aluminium..
DanzEterna
15,911
3,371
www.primeperdanaclub.com
in that case, u might need to
1. remove & check your thermostat whether is it in working condition.
2. how long has it been since u changed your water pump?
3. fan running at optimum speed?
milo87
79
2
1,508
1) owh.. can u give me any pic.. ehehe but not mistaken my mech already make the water flow without thermostat..
2) done overhaul for 11 month ago.. but donno if water pump got replace..
3) dont check it yet..
PS: my car happen like this after running on dyno machine for 25 run... :(
DanzEterna
15,911
3,371
**maybe u should use thermostat...its there for a reason
**u got reciept anot?
milo87
79
2
1,508
oic... got receipt but forgot where i put it.. huhu im on long journey this coming wednesday... from sel to kedah... so really worried bout it..
milo87
79
2
1,508
thanks bro... i spare 1 big bottle mineral... :)
im driving satria running on 1.6sohc engine
milo87
79
2
1,508
owh... huhu... im still hope the problem not the big one :(
xtremeleo
3,247
464
5,183
25 runs on a go? wahlann!!! on which dyno sir?
I need some help and guide here. I notice that the FLX RPM meter is lagging on each gear shift.
Example:
3rd gear up to 4th gear. When shifting from 3rd to 4th not matter how I shift after when I'm in 4th gear and already on throttle the RPM still drops before gaining back. This makes the RPM reading not accurate. Now before asking me to fix another tachometer (which will be my last resort) I want to know why 1st? why the lag? I'm thinking that the RPM meter on the FLX is reading signal...
