6a12tt-rs.perdana v6
jj.v6
332
13
johor baru
jj.v6
332
13
johor baru
well seems like not many perdana users out thr these few day??raya holidays perhaps...
TopRpm
295
46
no need to swap to 6a12tt rs la...only difference of 20 hp...
must as well get emanage piggyback or standalone ECU...
easily get 40-60hp increase.
yes..agreed with bro danzEterna..just put in e-manage, walbro fuel pump n up boost..easily can get 270hp...
p/s: my fren just put in e-manage, boost 1.2 bar with NOS kit..327hp achieve already...
as a prove..refer to dyno graph..without NOS and with NOS...
kanan
908
52
Bro Toprpm, block still standard or used differnet model?
budakkampungaje
317
Dengkil
the 6a12tt RS is from GALANT e84a(VR4)and E74a(VR4 Stype)-its preduce 240ps for manual 'n' for auto is preduce about 215ps......
MANUAL SPEC
Displacement, cc 1998
Engine model 6A12T (twin turbo intercooler)
Max.power (Net), kw(PS)/rpm 240 ps (176.52 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 31.5 kg*m (308.91 N*m) / 3500 rpm
Power density 5.96
Engine type V type 6 cylinderDOHC24 valve IC twin turbo
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger Twin Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.8
Fuel consumption at 60 km/h, l/100km
AUTO SPEC..
Max.power (Net), kw(PS)/rpm 215 ps (158.13 kw) / 6000 rpm
Power density 6.79
Engine information
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10.4
budakkampungaje
317
Dengkil
hmmmm...MIVEC...lot's model for the mivec Mitsubishi Emeraude Super touring-R-MIVEC-MD,Mitsubishi Eterna Visage R-MIVEC-MD ,Mitsubishi Galant Grade VX-R-MIVEC
MIVEC-MD
Engine model 6A12
Max.power (Net), kw(PS)/rpm 200 ps (147.10 kw) / 7500 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.4 kg*m (200.06 N*m) / 6000 rpm
Power density 6.35
Engine type V type 6 cylinder DOHC24 valve
Engine information MIVEC-MD
Turbocharger No
Compression ratio 10
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8
MIVEC
Engine model 6A12
Power density 6.35
Turbocharger No
Bore, mm 78.4
Stroke, mm 69
Final gear ratio
budakkampungaje
317
Dengkil
where to find sensor breake(at padel breake)for eterna@galant v6 twnturbo 4kaki...?spare part &half cut shop wish area....?
budakkampungaje
317
Dengkil
the brake sensor for wat ah? if ABS sensor i know...
anyways, u need to search those halfcut shops...some might have ,
some dont....
i already get the brake sensor i get at half cut shop at can saw lin road....i buy RM 30.....:biggrin:
---------- Post added at 04:11 PM ---------- 6 hour anti-bump limit - Previous post was at 03:53 PM ----------
some dont....
i want to ask you....i having a problem with ABS V6tt sistem my ABS indicator signal(at meter panel)is always menyala.:hmmmm:...when start the engine its should be off kan..?but it's still menyala..?....WHY AAAa...?this problem start when i'am buying v6tt half cut untill now....PLZZZZ HELP....:adore:
mhaziem_ke30
117
mine also the same..standard proton 6a12 engine..the ABS also on..donno why..:adore:
Hi,
Im currently driving a 1.6 sohc proton satria. I am interested in converting the head to dohc. Need all sifu's here advice on all the things and parts i have to get. Also need to know any reliable mechanic that can get the job done and total cost for the whole conversion.
I also need to know such a mod would affect my car engine in the long run? Would i have to change ecu? and finally the difference im bound to expect upon completing the mod.
I just heard about this and i...
