Bush for TRD anti-roll bar
JAP_AUTOPARTS
484
16
PENANG
Can any 1 help me look for bushes?? I m using super strut and i bought a set of trd anti roll bar....but it didn't comes with the bushes so i cant fix in right now...the front anti-roll is 33mm....i failed to get any bushes that can perfectly fit in :hmmmm: So got any sifuzzz can giv some opinions?? :adore:
levin818
1,260
321
3,183
Shah Alam
Hi JAP, are you referring to TRD anti roll bar for Levin AE101/111's (Superstrut version)?
If yes then the thickness should be 28mm.
I'm using Nissan's bushing, cut it into desire shape.
Hope this help!
450
Hope this help!
bro,how bout ae92 trd antiroll bar 27mm?izit can use nissan bushing?my 1 when passing d roadbump got 'ngok ngok'sound,n 1 of it got small gap can see thru between bush n bar,izit time to change it?thanks
levin818
1,260
321
3,183
Shah Alam
For all of these funny sound, leave it to your mech!
Once i have same problem like your's, and i have the same thinking as well.
At the end my mech found that the culprit was a deffective lower arm's ball joint!
Yes you can use that Nissan bush for your 27mm anti-roll bar. Just shape a little bit on its lips, and make sure it give 27mm when fully close.
2731
450
thanks bro,im sure tat sound is from tat bush,cos last time mech put sum oil on tat bush,then d sound gone.bro,wat model of nissan bush when i purchase?thanks
Dayline668
1,828
492
1,683
Can try find st caldina bush.. im using 18mm bush at the back, not sure the front same..?
levin818
1,260
321
3,183
Shah Alam
Hi 2731,
You may check the photo that i have posted.
I do not know its from which model, but it written "B13" and has the part number printed.
Any Semi-racing or better clutch that I can fit from other models..(or other makes..Proton/Mitsubishi?)
Details as follows for new OEM Nissan E13/E15 Japan clutch:
Diameter- 180mm
Pads - 16 pads
Springs - 6
Anchor Joints - 8
I went to a local spare parts shop and they recommended me this EXEDY (come from Japan)
Diameter - 180mm
Pads - 18
Springs - 3 (Why 3 only? :eek: )
Anchor Joints - 5
The guy said that it can`t fit a bigger clutch plate. (E.g. from a 180mm to...
