Satria steering wobble
fawzi
13
port klang
any one..! pls help me ..i have a problem here..
i own a Satria 1995, the problem was my steering a little bit wobble when on wavy road..
i already change the Tai-rod end , lower arm , cross member , power steering and steering rack bush.
But the problem still occur..
What i might think maybe the problem is from the steering shaft ( frm wheel steering under dashboard to steering rack..) plse any one if u have the before.
:driver:
Milo33
185
if on straight road and u speeding, the steering still wobble?
if wobble then need wheel balancing..
if not mistaken, after change the lower arm or dog bone must do alignment at the back..rite?
beatnik
924
74
3,028
Steering 'loose' feeling? what kind of alignment setup have u done? standard gaban? or got adjust camber kaw-kaw? how big are your rims?
do check your drive shafts as well..
fawzi
13
port klang
i'm use 15 inch rim
---------- Post added at 04:51 PM ---------- Previous post was at 04:50 PM ----------
already do alligment..still occur
---------- Post added at 04:59 PM ---------- Previous post was at 04:51 PM ----------
some of my friends told me lower arm will coz of this problem...is it right..? :confused:
i already change both lower arm 1 1/2 years ago ..i use middle quality item (rm60) and some said use original equipment or good quality (rm150) ..and u will find problem no more...
any suggestion friends..? :listen:
nam_s
86
2
3,008
Could be caused by suspension. Maybe time to change them...
Heres the answer to all your minor dents, bumps, bruises and scratches... say good-bye to them as Dr. Dent The Automotive Perfectionist is here to restore your rides away from dents and bruises.
Call Williard Yong at 012 238 1010 for a free consultation
