- Joined
- Mar 1, 2007
- Messages
- 1,730
- Points
- 1,648
Guys,
Need your opinion.
WHAT makes SENSORS go bad ?
Myself and some of you guys as well, seem to be facing this constantly.
I'm referring to our car's MAP & TPS sensors.
some of you know, In the past 1/2 year, I changed 3 TPS sensors, because they keep mati
tps failure causes the car to jerk due to incorrect reading of throttle %.
and 2 months ago, I changed my MAP sensor due to intermitten incorrect readings , and now, it's starting to fail again, causing the car to choke.
In your opinion, why do my sensors keep "kong" ?![Bawling :bawling: :bawling:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/bawling.gif)
I'm running RBC intake manifold and BDL 70mm throttle body.
is it water kena sensor?
is it the throttle body problem?
is it wiring / harness issues?
Opinions appreciated guys ! :wavey:
Need your opinion.
![Banghead :banghead: :banghead:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/banghead.gif)
