[Help]Springs?
Lim Ling Yang
63
Currently using hi-low adj cusco suspension and I feel that it is getting a little too hard and bumpy for me.
Could I change the springs to make it softer?
Or what else could I do?(Besides changing suspension no budget.)
And some people said changing springs is bad and might dmg the suspension.
contreasjun27
9,000 RPM
9,045
25
subang
yeah it will dmg ur suspension unless you are using back the cusco springs that is for your specific suspension
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
try change to other brand.... cusco is memang popular for its stiffness and handling performance... if u want comfort, try something else, especially produced locally for local spec.....
Lim Ling Yang
63
But the cusco still quite new and expensive.....
So there is nothing I can do?
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
sell it and buy other brand lo... since its still new, resale value shouldnt be vr low...
pektl
31
bro, you should just replace the springs with tein s-tech soft or medium tension. that should solve your problem. changing the spring will NOT damange the absorber. :)
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
u sure they are compatible??... as it the tein springs fits cusco coilover suspension??...
Lim Ling Yang
63
So there is really no other way other than changing suspension?
BananaBoyz
217
i use cusco hi lo,so hard then i change spring to honda eg spring rear 4pcs...
pektl
31
you can do a check. measure the cusco free spring length and the diameter of the spring. use it to compare against the tein or any other brands, if its the same, you can use them. :)
by the way i got tein spring for evo 4/5/6 going at SGD$80nett self-collect in Singapore.
Lim Ling Yang
63
So if the size is same I can use softer springs?
pektl
31
yes. you should be able to use the softer spring if the free spring length and the diameter of the spring is the same. cheers.
hello ppl, my boost meter light kong already, where can i send this meter for repairs? normally how much will it cost ?
thanks
