Vtec timing problems >> Need Views
pardypeople
Hi Guys,
A few days back I was late to work and eventually was doing some Vtec kicking on my way :biggrin: . What happen was, when I reached work I felt my timing not consistant which applies to both idealing and on the move. Now even on consistant speed, I get the jerk(fractional) feeling.What could be the possible problem? anything serious?
Kindly shed some light here...Thanks...Btw, I'm using a B18c gsr...
Thanks mates....
dying fuel pump - check fuel pressure
dying spark plugs - check spark plugs
loose ecu harness - pull and insert back
dirty IACV/throttlebody - clean them
dying distributor - check the coil and ignitor
clogged injectors - injector clean up
thanx J101...
A thread every 60 seconds
