Reset ECU by disconnecting the battery
evoace
58
Hi bros,
Izzit ok to reset ECU by disconnecting the battery terminal often?... I found my car fuel comsumption is better by do it.
Pls advise.
Tks
mag9556
2,770
43
1,648
Yup.. but not all cars..hehe...
koolspyda
2,889
55
5,148
KayEl
koolspyda.blogspot.com
generally newer "intelligent" ones. most "variable" types adjusts to driving styles.
however i cannot confirm about the pre-1997/98 cars.
evoace
58
wat car?........
Camry 2003. Someone told me to do that bcos if disconnect the battery and reconnect after a certain time period the ECU will reset in default mode.
So izzit advisable.
nonameNo
45
just need to disconnect the -ve point of battery and leave it for around 15 to 20 mins. then the ECU will be reset to factory setting. so it will record and recognise your new driving pattern style.
evoace
58
izzit advisable to do it often?
b00n
3,721
4
there's really no harm doing so.....
it's same as electronic device.....
but why do u need to do that often?!...
like what koolspyda commented; newer ECUs usually are inteligent whereby it would adjust to the drivers pattern and "learn". Unless of course you change your driving pattern every now and than; if not, why do u need to reset?
Usually ppl would only reset their ECU if they've done some mod to their engine; like changed throttle body, install new camshaft, injectors etc.......
Why?....because they wants the ECU to get used to the new "settings".
evoace
58
each time I reset, I get better fuel consumption.
b00n
3,721
4
each time you reset??...
meaning how long the interim between each reset?
Than I think u better get a full diagnostic on your ECU. Very unlikely ppl need to reset their ECU so often. Logic as I've explained earlier.
Could also be your throttle body or injectors got problem. Thus once reset, your ECU reads back factory settings for everything. Than slowly it "learns" about your fuel setting to suit your throttle. That said, if your throttle body or injectors are faulty, sooner or later the ECU is going to map back to suit these parts thus causing your fuel consumption to raise again.
So I suggest you get a full diagnostic to find out which sensor is giving you problems.
Joeker
Walking Dead
3,580
62
Jinjang
No dfference to disconnect ECU.
Wat the ECU do is just getting new data from engine sensors like TPS, water temp, air pres., 02, lambda, etc.
The maps in the ECU are fixed, they dont "learn" or "re-set".
When reconnect power to ECU, the sensors in the engine gives the new feedback for the ECU to look up on which point in the MAP to use.
I am a newbie in this car world so need a little help please..Recently i changed to a sport spring..After changing it i noticed the gap of my front tyres are different, one is lower, one is higher..Why does this happen ek..
