1jz E36 BMW frankensteining
Mitevo7
1,456
179
Cant a bracket be made?
Too much work and don't guarantee can work. Change the pulley is easier, the job was done with only 180 bucks.
Thanks,
Ken
Mitevo7
1,456
179
Normally when it is not plug and play, and need modification, sure will cost more and take more time also....
Yup, prioritize is one of the key things, for the alternator, for now the smaller pulley solves the issue, i will leave it for now until i go for high performance fuel pump.
Now prioritize on cooling, low temp thermostat and fan controller (by Shadow).
Thanks,
Ken
Mitevo7
1,456
179
Guys,
I can confirm my electricity issue was solved after few days of driving. Power windows, RPM, lights all are working at optimum efficiency. Moving on to handling, although installed with P9 Premium Shock absorber, i can still experience some degree of roll in corners. Due to the fact that my E46 originally was a 318ci, there's not much more brace bar came from the factory. So far i've gathered that 318ci has 15mm front sway bar and 16mm rear sway bar. Are they any other brands other that Ultra Racing that makes sway bars for Non M E46?
Thanks,
Ken
Reactions: ^pomen_GTR^
Guys,
Thanks,
Ken
15mm front???? That's tiny! Even Wira front sway is 19/20mm at the very least. If i'm not mistaken UR is the most cost effective. The other brands are Eibach and KW but I don't think you'll want to go Euro route considering the price difference.
Mitevo7
1,456
179
I reacted the same when i measured it with a scale, i am very surprised that stock bar is so tiny but the car handles very firm and planted with its original 1.9 Litre engine. That's Euro chassis magic to you.
UR bars huh, well in my case what bars do you think is most essential to accommodate the new found power ?
Thanks,
Ken
Thanks,
Ken
front and rear ARB, and and bars in the middle
Guys,
Thanks,
Ken
i think ultra racing arb is bigger? might be better go all UR item as well
Mitevo7
1,456
179
Yes UR standard settings are 21mm or 23mm front, 19mm or 21mm rear. Stock 318ci uses very tiny ARB. Getting quote directly from UR and once install, i am going for brake mod.
Thanks,
Ken
sweelt
Nov 6, 2016
2,306
248
Thanks,
Ken
For my wira - front top brace, fender bar, room bar, rear arb, rear top brace.
Front arb stock gsr already 23mm.
Hello friends
A very good Thursday from Mauritius :wavey:
This detailing job took over 5 days, from decontamination to coating, loads of defects removal and paint leveling.
Upon arrival:
Wash:
2BM method using mf wash mitt
Local car shampoo and APC mix...
