4g93 Mivec Turbo Waja project(Many pictures be warned)
Nightstalker1993
267
130
Subang Jaya
i dont know where i put my dyno sheet, cant recall the torque . peak hp around 5k ish rpm and peak torque around high 4k rpm, thats why i limit my rpm at 6.5k rpm.
running and tuning 97.
Fuhhh nice la peak torque 4k RPM. Mine peak slightly higher at 5K RPM, but pulls alot longer kot, since peak HP is at 7000RPM and even above that still the HP doesn't drop off that quickly. i suspect my downpipe might be a restriction as I am using the original EVO downpipe, and also the fuel quality... But damn reluctant to run on RON97 :laugh:
Sup guys, been some time since I've updated this.
Not much had been done/happening on my car as I have a motorbike and also a Volvo S80 now so I rotate between the 3 vehicles. Last Saturday I managed to hit the dyno though, and here are the results, before my accessory belt decided to say goodbye. 235hp and 276nm of torque on a Dynokraft dyno, whose numbers are pretty understated, similar to Mainline's numbers. If you see the chart the highest run I did was around 245hp, but that run was knocking and I had to dial back on the ign timing to avoid knock.
not bad... mine 1.1bar 247whp/307nm torque on awd .driver:
Mmmmm nice one la stock standard boost, no need pening pening weird ass problems like me, just simple reliable power :biggrin:
standard engine and turbo..
but not running non standard boost level...
ANNNDDD i have to redoing almost everything the previous owner jackass mechanic...one example... i found more stripped bolt than the good one while working on it recently...
Which should make u even more confidence with that ride...it survived multiple stripped bolt, surely it can take a beating.
Nightstalker1993
267
130
Subang Jaya
wahh, so my car is almost the same power level as a subaru with increased boost level haha
Ok la, at least you found the bolts before it started causing an issue
maybe...haha...im pretty soft on car engine...but not so on suspension :driver: coz #rallydriver :rofl:
its wrx engine with 240/250hp on flywheel from factory.... so 247hp on AWD wheel is OK to me... haha... (its about 280hp on flywheel since awd gearbox robbing much of the power...and the turbo maxed out already..since the stock TD04L is pretty small).... the 3xxNM torque is good for street driving and touge road balik kampung....coz thats what im using that car mostly...
future plan maybe just about 360whp when its time to do full rebuild...maybe 10years later... we'll see... :biggrin:
but your car maybe faster...coz lighter body... :driver: it sure does feels light at acceleration when boost+mivec kicking in... :driver:
as seen from the title above, i suffer from low oil pressure....low rev is ok i think, since idle stay at 1 bar plus, crusing stay at 2 -3 bar.....how ever, the oil pressure stay same when i full throttle and rev, when high rev till vtec and boost kick in, pressure dropped to 2 bar only:banghead: new oil pump needed? where can get it? and got aftermarket pump that is more efficient and powerful? will that cause problems if i drive it normally(not rev past 4k rpm and no boosting)? please...
