Bro, he has idle issues. Alternator not supplying enough during idle. Like I said earlier, if alternator consistently undercharging, the battery simply goes flat very soon
simply need to drive faster
![rofl :rofl: :rofl:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/rofl.gif)
![Driver :driver: :driver:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/driver.gif)
Open road can lah, traffic jam how?.....hhahahhahahhahahahasimply need to drive faster![]()
Next car think you challenge him for race.....hhahahhahahharev2 the car....![]()
A car at idle is not at it's most powerful rpm. So when compressor kicks in, it places an additional load to the resting engine. Hence rpm drops momentarily till ISC takes effect and raises the rpm to compensatemy wira cruising like 13.5V with aircon ON or OFF.
When idle, aircon compressor kick in it drop to 13.0V (rpm also drop) for short moment then regain 13.5V normal idle 900rpm.
May i ask , is it aircon compressor problem or "berat" ? Idle rpm take a dive to 600rpm momentarily.
Yes, due to extra force required to turn the compressor, that is hwy need the FICD/IACV to increase the idling speed......my wira cruising like 13.5V with aircon ON or OFF.
nothing wrong with the compressor lah ... ? jimatYes, due to extra force required to turn the compressor, that is hwy need the FICD/IACV to increase the idling speed......
Compressor Nothing wrong, just that since the compressor needs extra power to turn it, the engine idling drops before FICD compensatenothing wrong with the compressor lah ... ? jimat
Thats the nice way of putting it. The truth is that your engine is not powerful enough...hihihiCompressor Nothing wrong, just that since the compressor needs extra power to turn it, the engine idling drops before FICD compensate
aiyooo....Thats the nice way of putting it. The truth is that your engine is not powerful enough...hihihi
GSR woh.......hahhahahhaaiyooo....
am ok with current engine, cukup dah.
Not enough juice..Hi All,
Since sweelt talked about A/C, just want to check, if alternator has not enough juice, will that affect the timing of A/C compressor kicked in? I found out that the A/C is slow to come in during slow traffic, where RPM constantly stays below 2k rpm. Once got on the free way and the A/C works just fine.
Thanks,
Ken
Have to check whether the clutch not engaging or your air con refrigerant is low. When refrigerant is low it does not cool fast either especially in slow traffic. Once you speed up the compressor turning fast so the refrigerant works faster and at the same time at faster speed the condenser gets cool faster also.....Hi All,
Thanks,
Ken
More evident in smaller engine with small compressor ie kelisa, kenari, kancil. Revving between 1500-1800 rpm during stationary will improve cooling which can be felt.Have to check whether the clutch not engaging or your air con refrigerant is low. When refrigerant is low it does not cool fast either especially in slow traffic. Once you speed up the compressor turning fast so the refrigerant works faster and at the same time at faster speed the condenser gets cool faster also.....
Yup, there is a sensor, usually at the receiver dryer. This to help prevent compressor damage.....More evident in smaller engine with small compressor ie kelisa, kenari, kancil. Revving between 1500-1800 rpm during stationary will improve cooling which can be felt.
Some ac system wont engage the compressor at all when ut detecs low refrigerant.
My personal exp with waja that has worn out compressor clutch is it wont engage during jam. Once i rev above 2k rpm it will engage. temporary repair is modding the clutch which help for about 6 month before replacing the compressor.
anyway, i suggest to tackel the current issue first.i bet it has something to do with it.
Not enough juice..
Worts if the compressor clutch is worn out as the compressor wont engage.
Similar threads | |
