Kancil 660 Air Cond Amplifier Setting
wilm3
500
29
dear sifu,
Any sifu here know how to set/adjust the Air Cond Amplifier?
lsm1991
1,469
185
Air Cond........... Amplifier??
*reads a 2nd time*
:confused:
not sure if this is a thing? a thing that exists?
Got woh! Google and got this.....lol
A/C Amplifier Products
If your air conditioning system has a heart, it would be the compressor. It keeps the flow of the whole system in motion by compressing and transferring the refrigerant gases. But for before it starts doing what it does, another component is needed to take control of the compressor. And that's exactly what an A/C Amplifier does. If the compressor is the heart, this device is the brain that handles its overall function. It serves as a control module which directs the operation of the compressor based on various inputs like evaporator temperature, low-pressure switch, and A/C request. Aside from this function, this component also acts as a protection device. It's able to do this by comparing the speeds of both the engine and compressor. By determining whether the speed of the two devices match, the amplifier is able to prevent the compressor from incurring any damage by turning it off when its speed is not in sync with the speed of the engine. Due to its important role, it's important for this device to have a long service life. To ensure this, each one is made from premium materials to help it withstand wear and tear. It's also customized to match most vehicle specifications making it a suitable replacement for your worn-out component. The A/C Amplifier works together with the compressor to give you that the right temperature while you're inside your cabin. So make sure your ride has this device today by ordering one through our selection of parts right here at Auto Parts Warehouse.
Wah... i am 33 years old and this is my firt time hearing abt this.
Must be a small box or in case of modern vehicle its built in the ecu eh?
Same here, have been fiddling cars with my mechanic have not heard of this before until I google it.....lol
Yup, something like a control box
Isn't the amp pre-set and non-adjustable?
Should be preset in older cars. Now i understand why my bro w124 wont trigger its aircond fan when the gas pressure is not right.its the amplifier doing its job.
On modern car with high tech ecu it could be built into the ecu.
On the Kancil i doubt its adjustable.
lsm1991
1,469
185
holy cow its a thing! a thing that exists!!
you learn something new everyday
wilm3
500
29
The Kancil A/C Amp is attached behind the passenger glove box. it can be adjusted. My A/C foreman adjusts it but end up he messed the setting and said "is like tat la"... now i hv to try n error ....
parakey
1,367
226
For Kancils, it's that thingy you adjust to determine when ac should cut off when engine is short on power. Mine was messy for many years till I finally got it replaced. Now okay already
how do i take off side fender kancil is it got 2 nuts?
then after removing got lots wires or not from it cause side have signal.
reason want to knock back fender dent . thanks gang
