Best tire for a riM
Domenick palumbo
Apr 19, 2018
53
Hello I’m looking at purchasing a 17 x 7.5“ aftermarket rim for my 2015 Mini Cooper hardtop.
I want to put summer tires on what is the best tire
205/40r17
215/40r17
Some people have talk to see the 205 is too narrow but the 215 would be good ???
205/40r17
215/40r17
I google and for 2015 mini cooper shows 205/45R17. 40 series might be too small
205/40r17
215/40r17
The Mini is already pretty hard riding. If you downsize to 40 it's going to add to the harshness
205/40r17
215/40r17
max size for 7.5"jj rim is 235 width...
but really optimum width is 225...
with 215 is a little bit stretch...but nothing dangerous...
215 or 225 would be the better fit for 7.5jj rims. 225/45/17 I think might be too big if your stock is only 205/45/17 coz sidewall is already 0.9cm taller. If 215/45/17 then will be a bit more comfortable than the stock 205/45/17 coz sidewall will be about 0.5cm higher but still not too big. If 225/40/17 will be slightly less comfortable than 205/45/17 coz sidewall reduced by about 0.2cm.
Domenick palumbo
53
My original tire and wheels is 195-65-15 so going to stick with 215 -40-17 summer tires if I don’t like ride I’ll switch to 215-45-17 next summer. Car is total stock right now the summer I plan on putting coil over suspension on it
If original is 195/65R15 then 215/45R17 is not a problem. In fact 215/40R17 is too small already. 225/45R17 also can fit, but scare only the width will scrub your fender. 215/45R17 also have many tyre choices.....
Domenick palumbo
53
I don’t understand how 215-40-17 is to small 215-45-17 isn’t that much bigger
215/45 has sidewall height of around 9.7cm (21.5cm X 45% = 9.7cm) while 215/40 only has sidewall height of 8.6cm (21.5cm x 40% = 8.6cm). So the radius is smaller by 1.1cm, meaning overall/outer diameter is smaller by 2.2cm!
Now compared to your stock size 195/65/15, the overall diameter is actually even bigger at 63.5cm while 215/45/17 is only 62.5cm. Imagine if using 215/40/17 which is only 60.4cm, it will look so small! Diameter wise, actually then the best match are either 205/50/17 or 225/45/17. If use 205/50/17 then easier to clear but if 225/45/17 then you need to make sure you get rims with more precise offset so it would not rub. Ideally you should then use 205/50/17 but this size is much more rare, while 225/45/17 is much more common.
You can play around with this tire conversion calculator to understand better what I've said above:
https://www.wheel-size.com/calc/?wh...-17X7.5ET39&fcl=30mm&scl=50mm&wcl=30mm&sr=0mm
Reactions: vr2turbo
Domenick palumbo
53
So I went with 215-45-17. So it make it look bigger on the car can I go with so 215 -55-17 and clear wheele wells without a problem. I want to stats to look better make the car look better without. Affecting the wheel wells on the steering I don’t want to be R affecting the wheel wells on the steering I don’t want to be Rob ib so if I went with 215-55-17 next time will it ride better make stances look better
Cannot use 215/55/17, way too big diameter at 5% bigger than stock size. In general, you should not exceed 3% bigger tolerance compared to your stock size. If too big diameter then your car will suffer from poor acceleration, fuel consumption, and braking. Just check the calculator I gave you above, it will show you the calculation when you play around with different sizes.
Domenick palumbo
53
Yeah I’m having a difficult time with that understanding it so 215 45-17 as big as I can go as far as height for tire
Hi All,
Any one here / friends who lost their car recently?
Noticed that there is a Nissan Sentra (Original Gold color, 05 ~ 07 model) with reg. no. WMS 86xx seems abandoned in my condo, clamped by the management for the past 3 weeks.
Do contact me for more details at [email protected]
Cheers
