Buying a Perdana
pathfinder
231
Hi
Im in need for a 2nd car ...with limited budget. I don't want to finance/loan. So, Perdana is right candidate. ..roomy, comfort, sufficient power and affordable spareparts.
Max budget rm10k
Should i go for SEi non v6 or better v6? V6 is sweet engine. But a bit afraid of extra maintenance. Even after Proton fitted atf cooler, the gearbox still problematic or not? Other than gearbox, what are common problem?
For SEi non V6, what is last production year?
Please give some comments on SEi vs V6
Thank you
RENESIS VIII
7,063
950
Ipoh
Perdana SEI last production year is on 1998.
I think in my opinion, SEI is the cheaper option to maintain since it is using an inline 4 engine compared to V6. V6 engine definitely requires a higher maintenance costs due to 2 extra cylinders. Workmanship costs for V6 is also higher than SEI.
Look at it this way.
4G63 SOHC (SEI) VS 6A12 DOHC (V6)
1 Cylinder head VS 2 Cylinder Heads
4 Pistons VS 6 Pistons
1 Camshaft VS 4 Camshafts
1 Cam pulley VS 4 Cam pulleys
1 Exhaust manifold VS 2 Exhaust manifolds
DanzEterna
15,910
3,371
www.primeperdanaclub.com
12valve vs 24 valve
4 spark plugs vs 6 spark plugs (workmanship is expensive to remove the rear plugs)
pathfinder
231
Haha..Thanks guys
V6 is cheap now. So tempted
Both SEi and V6 engine are reliable?
Any problematic sensors?
Spark plugs cost to change maybe can use expensive plugs, change every 80,000km = 3 years
Any tricks to enhanced gearbox reliability?
Maybe use fully synthetic atf and larger atf cooler?
pathfinder
231
Hi
Original V6 absorbers made by Kayaba or Apm ?
Anyway...which lowering is best? lower but acceptable comfort ride
kurt_629
872
54
johor
Once lowered the travel is less, comfort sure less dy......
yeah.. not forgetting you need to change lower arms, drive shaft etc..
every year, its becoming a part of the SOP.
my mechanic told me yesterday that my drive shaft is gone again..
3 set within 3 years..
I guess it must the kampong road that is killing them..
high hump + lowered = spend $
30,002
Or you boost kuat kuat.......lol:driver:
kurt_629
872
54
johor
Kurt,
How much is drive shaft per side?
ermm, if I remember correctly
The one in green, is from evo, cost me rm 350 and I also modify the rubber to silicon type.
the one in black, is v6 type, cost rm280 for a recon.
my mechanic told me, sei is actually more suitable.
I only know drive shaft is expensive and common problem with perdana, always need to change.
this is the 3rd time I am changing again
marsha1l_v6
666
130
543
powderful car..of course frequent change :adore:
