Car cannot start
resh9999
109
10
Car unable to start after three months sitting idle. Negatif connection on battery was removed. What could be the reason. Lights , side mirror working. Clicking sound is there
Sent from my SM-N910C using Tapatalk
30,002
3 months should be flat battery.....even new battery will go flat after 3 months left idle....
resh9999
109
10
Just change the battery . Can start now. But why does the ekzos smell like paint
30,002
You should try jump start then drive around to charge up the battery. I don't think it is dead, just ran out of juice since not used for 3 months.
Smell like paint? That is new. If it is heavy petrol smell, could just be heavy fuel feed, but after run for a while should be back to normal....
30,002
Thank you. Should give my feed back. Jump start fail .
Okay, through my experience for jump start.
If battery is completely dead like yours, to do jump start you will need very thick cable. Sort of the 1000amp type that you will find in hypermarket.
Donor car must be started and let charge run for a while before cranking dead car.
If battery have power but not strong enough to crank, a 600amp cable might work. Forget those 200amp cable. Too thin to transfer the current....:driver:
stutzedward
3,416
561
I had this problem in my Atr last time and it was due to old weak starter. It was like weak battery with ticking sound. However after added a relay to the starter, the problem has lessen though it still happen once awhile. Ultimate fix is to get the starter replaced. Anyway, I replaced the car. Hahaha....
30,002
May not be the starter also. Like mine is new starter but like you mentioned sometimes work, sometimes don't. Is due to old wiring or ignition switch, too much resistance. Adding the relay hooks up current direct from battery mah......lol
Sometimes jump starting using cables might not work if the battery is really out of juice due to being idle for too long. What you need to do is just swap the battery (if you have another one), start the car then quickly swap the battery back while the car is still running. Then just leave it for some time or drive around to charge the old battery back.
30,002
If cable is with thin type then cannot. Got one time ex colleague called say car cannot start, so we drove to her house, to check it out. Turn key to crank got tak tak sound only. So she show us her jumper cable she has, then we hook to our donor car, but still cannot start. Told her maybe starter kaput, so we call our mechanic. He came took out his thick giant cable to jump start. Immediate loud crank and car started.
Our company audio show car, battery flat. It was completely flat as no tak sound even. Colleague took out his jumper cable to jump start got tak sound only. Then call me if I can help. I took my jumper cable add to his (double cable) and car started....:driver:
Your way sure can start, more work only......hhhahahhahah
Yes, if emergency then just do like what I mentioned rather than keep looking around for thicker cables which still does not guarantee will work. So it's good if you know how to do swap batteries quickly while the engine is still running, then you don't depend on the cables as much.
30,002
My first intention was to inform if anyone is buying a jumper cable go for thick one. To get someone to loan the car to jump will be easier to ask whoever to remove his battery and loan to you to start the car.....hhahahhahahhaha:rofl:
Yes but knowing how to do it fast is no harm either coz you might really need it one day. You may think the cable you buy is thick enough but if unlucky might still be not enough (the cable is thick just because of the insulator thick but not the inside!). Of course you remove the car battery yourself la, don't ask the other guy to remove it for you leh! :biggrin:
Forbes has named the 10 most sexiest cars in the world in the year of 2007:
Sexiest Car for Hip-Hop Moguls: Rolls-Royce Phantom
Sexiest Car for Hollywood Agents: Lexus LS Hybrid
Sexiest Car for Miami Beach Plastic Surgeons: Lamborghini Murciélago Roadster
Sexiest Car for Mobsters: Cadillac Escalade & EXT
Sexiest Car for Newly Divorced Dads: Chevrolet Corvette Convertible...
