About the extra fan
18quattro48
Ipoh Peraj
I want to put extra fan in perodua kenari,i dont have experience in it at all,i want to ask the wind should blow inside the engine or blow it out?and i want to wiring it to the compressor,so when i turn the aircond the fan also spin,can everybody teach me how to jump the wire to the compressor while using the relay
Sent from my SM-N9208 using Tapatalk
The best and safe way is spend some money ask expert to do it for you.. i mean wireman that know aircond..
Extra electric fan. Blow in. Can place it to run when car start if always in traffic jam.
Depends where you have to space to fit the fan. If behind radiator means engine side then the fan should draw in air. If fan is fitted to outside, means grill side then it should blow in air.
Check your original fan where it is linked to? Usually if have 2 fans, one is link to radiator and one to air con to trigger them....:biggrin:
Check your original fan where it is linked to? Usually if have 2 fans, one is link to radiator and one to air con to trigger them....[emoji3]
Thanks for the advise,do u have tutorial how to jump the wire fan to the compressor,when i turn on the compressor it also turn the fan on
Sorry do not have. Anyway different car different wiring diagram too. I do DIY at home like flush brake fluid, change plugs, light tuning etc., but comes to wiring I still let my mechanic do that....:biggrin:
Sorry do not have. Anyway different car different wiring diagram too. I do DIY at home like flush brake fluid, change plugs, light tuning etc., but comes to wiring I still let my mechanic do that....[emoji3]
Okay thank you for the advise
need relay...tap wire from ac compressor [for magnetic clutch]..to trigger the relay for supply power from battery
once the compressor running, the additional fan also spin
not too complicated, but need little knowledge about auto wiring la
diy to my ke70...fan located between radiator and ac condenser
The thing is, if layman won't know which wire to tap. Tapping also must have some skill without cutting original wire....:biggrin:
Wah! Usually radiator and A/C condenser not sandwiched side by side? How you put in between?
well...u kno la...ke70 using direct to engine for radiator fan...very little space
first i removed the fan and shroud, then replaced it with radiator fan from kancil...and temp. sensor[at radiator hose] from proton
make it automatic electric radiator fan plus manual switch
then add about 2" spacer for radiator, to allow the additional ac fan [12"] sandwiched between it
then walah..hahaha:proud:
Change belt fan to electric fan I have seen before but sandwich is first time......:adore:
A Post Every 5 Minutes
