New Turbo VW Vento priced between RM80-90K, launches next week!
kcng
734
235
Selangor
kcng1983.blogspot.com
on a serious note... when people complain about the DSG7, has they look into understanding how DSG is supposed to work or do they just drive it like a normal torque converter automatic?
Izso knows how often i trashed and tracked my DSG7 and i think he is surprised that its still standing up to my abuse on a daily basis...
correct me if i am wrong CK...
haha....
RM 50k?
Want?
haha....
RM 50k?
Want?
In all honesty if I were in a better financial position I'd sell the STD and buy over your car for 45k :rofl:
Tom
TIMETOATTACK
5,562
3,229
enlighten us, how one should treat the DSG7
I heard from ericmaxmann, that owners should go full manual especially in traffic as to not allow DSG to continuously hunt for the next gear
kcng
734
235
Selangor
45k without the BBK and coilovers... but the rest remains...
ok?
:biggrin:
from my limited experience... i notice that the DSG7 up-shift to D2 even on speed as slow as 4 km/h.
So if we look at this scenario from a manual car point of view, if we are to use 2nd gear in such low speed, we will most likely be half-clutching right to prevent the car from stalling?
and what happens if u keep half-clutching? heats build up and until a certain level your clutch will start slipping and finally give-up altogether until u cool it down... (those stuck in jam going up genting will know..)
so being a dry-clutch unit... if u keep letting the DSG7 half-clutch, u get heat build-up in the clutch and this causes the Mechatronic "Shift-piston" to not be able to engage properly (as metal expands on heat) and by forcing the "shift-piston" thru the opening, chances are that this action causes the "shift-piston" to bend or displaced thus signalling the end of the road for this mecha unit.
(That is why on DSG7, on slow speed if u are to wind down the window, u will be able to hear "clark-clark sound" coming from the engine bay.. that is basically the DSG7 mecha shifting/engaging).
(Another factor could be the heat build-up causes the solenoids drivers to fry thus ending the life of the mecha, but this is just purely my theory)
so by going manual, u are only engaging D1 and not allowing the gearbox to upshift to D2 and by this u lower the period the gearbox is spent "half-clutching" and thus reducing the heat amount built-up.
now mineral oil is claimed to solve the problem question.
in my opinion, mineral oil is thicker and running thicker oil usually means you can tolerate higher heat... (that is why track car uses Xw50 or Xw60...)
so by putting mineral oil, it is hope that DSG7 will be able to have higher heat level toleration and thus minimizing the chances of failure. the trade-off in this is that u will get slightly slower shift-time.
that is my 2 cents view sorely based on my limited experience with my own DSG7...
:adore:
P/S - if they claim to have a revised mecha for the Jetta CKD DSG7 compared to the CBU, i have backend proof that they are basically the same unit, with difference only in Serial Number, Manufacturer Number, Date and Flash Tool Code.
:biggrin:
kcng
734
235
Selangor
PP/S - I am not trying to imply that the DSG7 is godlike, but rather with properly adapted driving pattern, u will be able to take better care of it and thus pro-long its usage and durability...
:driver:
Tom
TIMETOATTACK
5,562
3,229
:adore:
:biggrin:
Very interesting kcng, thanks for sharing with us your findings. This post deserves a thread on its own as a reference
I can relate to the low speed 2nd gear situation you mentioned and yes, the clutch would likely part engage to deal with the low revs for the said gear number.
:driver:
DSG7 and you got good matching......hhahhahahahha:driver:
MKMD428
876
190
5,043
johore
he got it figured out i guess, doesn't seemed abnormal to me and kcng explanation is very good. lets just embrace the good technical explanation rather than flabbergasting state of mind
for my iswara stock....now im using unbrand air filter...i would like 2 change 2 hks....anyone got comment on this modify??? any where can i get the HKS air filter cheap? any one selling..but i want new..no 2nd hand........thanks yaaaa ZTH member !!!!
