Buy one and start business......hhahhahahahaIf some ppl think that sandblasting oredi expensive, then laser treatment will be out of the question....
YEah...start small and steady, as they say.Sandblasting machine oredi cost a bomb imagine a new tech like this!!i bet it's worth a new 7-series beemer..
Off topic a bit. Like my friend tyre shop, just buy balancing machine and tyre mounting machine which are really needed in tyre business already cost a bomb. China made cannot last so need to buy more expensive machine and then balancing and mounting cannot charge customer because it comes free with tyre purchase. If buy alignment machine some more, really the installments will be hard to cover.....lolBaru start d biz have to shut down oredi coz installment too high n x cope haha
Use angle grinder and brass brush wheel is cheapest.....hhahhahahhahahhahaYEah...start small and steady, as they say.
Use sandblasting machine first, then if got money. ada rezeki and strong demand from customer....then might consider buying the laser blaster.
I actually sent an inquiry email to ask. Hahahahaha..N x to mention super expensive...
U be surprised bro..it's definitely x d cheapest or d easiest thing to do...so time consuming n tho d items r 'cheap' d labour will be expensive...u also have to take note that if u use angle grinder n brass brush u will be leaving a lot of massive 'scars' n prepping them is x easy nor cheap...Use angle grinder and brass brush wheel is cheapest.....hhahhahahhahahhaha
Cheapest for machine only, workmanship not counted......hahhahahhahahU be surprised bro..it's definitely x d cheapest or d easiest thing to do...so time consuming n tho d items r 'cheap' d labour will be expensive...u also have to take note that if u use angle grinder n brass brush u will be leaving a lot of massive 'scars' n prepping them is x easy nor cheap...
wow that's pretty expensive coating, repainting your car won't look as great as the original, you should always protect your car's original car paint! :)If d cost of coating is,say 3k,Honestly if it was me I rather respray d car...for that amount u be able to do a color change :)
