If keep to 15", 195/55R15 got plenty of choices, but 195/50R16, I found only Kumho Solus HS51, Yokohama A-Drive AA-01, Yokohama A-Drive AR01 (Directional) Falken ZE-912 now ZE-914 and Conti CPC2 which is going to be discon also.Ya....if PS3 have this size I will use back PS3 but PS3 don't this size
My original size is 185/60/15 I changed to 195/50/16...if I use 205/45/16 is it suitable?
I hope to find a tyre like PS3 or nearly PS3 and noisy abit also ok...need good grip wet/dry And good handling,sharp steering respon..
If Dunlop I like the sport max RT and Sport Maxx TT but I dun think both have my size
For you upgrade from 185/60R15, 195/50R16 is the closest, being 0.27% smaller only.
If go to 205/45R16 it will be 2.01% smaller. Can still use but will be bumpier but better traction because wider contact. How wide are your rims? You need min 6.5" to max 7.5", best 7" wide rims
You can also use 205/50R16 which is 1.37% bigger, slightly better comfort to 45 series.
Both sizes PS3 have....
Is your car lowered? If not, then using 45 series more space in wheel arch....
