I have a pair of 10" woofer boxes at my perdana boot. and i planning to make a custom speaker box separate on my left n right side of the boot. Does it make different sound and what is the cost of doing a custom box?
Free air subs? Were they hanging on the rear parcel shelf or in a box? Depending on the specifications of the sub, making a custom box at the side may or may not make it sound good. Look good yes - sound good depends on the sub specs. Most 10" subs work best with 0.8 or 1cuft sized boxes. If that mould is spec-ed to that approximate size then yes - it'll probably sound good.
Free air subs use your entire boot as the box, shrinking it to smaller box might have a difference in sound. I can't tell you what sort of difference though since I don't know what subs you have. I probably haven't heard them before either so I wouldn't be able to tell even if I did know.
As for cost, depends on the shop and their handiwork. These custom fibre boxes can cost anywhere from RM500 to RM1000.
OH.. in that case it'll sound different for sure. And I'm not sure how you're going to separate the subs since they are probably wired together and powered by one amp.
izzo, actually i would like to hear your set up. as i have just gone from a bigger car to a smaller car im thinking of subwoofer options. putting a regular passive 10 in woofer in a small car takes up loads of space. i have been looking around for an active sub but am not convinced of its ability. so i would like to hear your sound system if you dont mind. fyi im not looking for big boom, want clear bass with some punch.
Arrange a time and I'll bring my Myvi along.
I thought your STD. Should have let us hear ICE in your the Myvi......![]()
Can't carry 360kg worth of people!
Similar threads | |
