Hello All -
When my car was parked, it got flooded, and the water came into inside.
I didn't start the engine, and it was towed to perodua. I asked them to change ATF Oil, Engine Oil, change all filter, and dry the petrol as well.
After I collected, and drove to Genting. At home, I saw the AT (Automatic Transmission) light in dashboard turn on. It impact every time the gear move to higher one, the car choked. :(
I sent to Perodua, and they said that the issue might be on Wire on Gearbox, or ECU. They want to change the Gearbox wire first, if it can't help, then it needs to change ECU (they are still not sure where the issue is) . However, they don't have a stock on the wire , and even in Kilang doesn't have as well. Hence, I need to wait.
The car is almost parked there for one month. I can't tahan, I collected, and asked them to let me know if the wire is ready.
When I drove back home (distance is 10 km) , the AT indicator in dashboard didn't turn on, and I didn't find any issue when Gear is moving to higher gear. However, when I drove down to KL from home (distance is 14 km), the AT turn on again, and I felt the issue in Gear again.
And when I drove back home from Bukit bintang, the AT Light didn't turn on, and the Gear worked fine.
I would kindly like to ask your thought on this -
1. Why the issue is like intermittent, sometime it turn up, and sometime not? Is this due somehow the wire isn't dry properly, and it needs time to let it dry?
2. Should I still go to change the gearbox wire? Or I just need to wait for another time since it needs time to dry properly? Or I should change the wire?
3. I am bit mad due the wire has no stock for almost 1 month, some more this car is a local car, it is not something that it needs to import from overseas. Do you have any idea if I can check by my own which perodua workshop has this wire? Or do you have a contact number for perodua HQ workshop that I can check for this wire?
4. Do you have any idea how to fix it? Since I am already very frustrated on this?
5. Do you know where the perodua workshop who has good mechanic? I would like to have 2nd Opinion. My place is near Cheras.
Nb: my car is the new MyVi 1.3
Kindly please ask your thought, and appreciate it much.
Thanks,
---------- Post added at 11:21 PM ---------- 6 hour anti-bump limit - Previous post was at 10:01 PM ----------
Hello All - Appreciate for any of your thoughts.
Thanks,
