change from 1zz-fe to 2zz-ge engine
jasonw800i
39
1,508
if for halfcut auto one is it 4speed ect ah, cause i read there in wikipedia auto is 4speed ect and if manual 6speed can use on wish triptronic gearbox mah?
jasonw800i
39
1,508
in kl site any sifu is pro in dismantle engine and do pnp from other engine for this case?
cause halfcut not hard find but for labour is abit hard find that reliable sifu and reasonable fee
KenDiriwan
1,283
225
kendiriwan.multiply.com
Plenty, thing is what if it is not PnP? Mounting fabrication needed that you might even risk endorsement ? Anyway i am not sufficiently detailed to tell what body compatibility on what engine. What area do you prefer ? Let see what i have in mind to point out.
KenDiriwan
1,283
225
Powerspeed Kajang, Ah Nga
Trial Tuning Sg Besi, William
Danny Auto Work & Service Pandan Indah, Danny
jasonw800i
39
1,508
i also regret buy new and if sell sure rugi much
actually i should buy secondhand wish and transplant 2zz is more save cost hehe
Supra_Fanatics
20,685
3,998
Should be buy a 2nd hand modded wish with 2zzge :biggrin:
jasonw800i
39
1,508
now regret also no use
but thinking if don't want transplant the 2zz engine
also beisde put turbo
can do other upgrade make it add hp or like somthing tune the gear ratio?
Supra_Fanatics
20,685
3,998
To increase hp for NA, the amount u spend will be more than you achieved on NA. Unlike turbo which is more worth modding. BOT is another option if u dun want to transplant. Still best get a good workshop to do it. Is not as easy as it sounds.
tom's
2,865
76
subang
www.zerotohundred.com
light pressure turbo or Supercharged it would be good enough.... i'm planning to fit mrs 1zz turbokit into my wife 1ZZ RAV 4...
Supra_Fanatics
20,685
3,998
1ZZ Rav 4? Transplanted engine bro? from 2.0L - 1.8L wor bro.
Btw, would like to know the MRS 1ZZ turbokit is it still available new or half cut?
Supercharged ask before, that would cost like RM5K. How much to install that turbokit into your 1zz rav4 bro?
jasonw800i
39
1,508
yalah 1zz turbo kit is consider as light pressure turbo
something like honda civic or lancer model which is have built-in turbo so it will auto open turbo will reach 3k rpm like that ?
30,002
Either turbo or Super, both need quite a lot of work. Tuning, reducing the compression, fuel feed and so on and of course the main thing, BIGGER wallet.....:rofl:
---------- Post added at 04:47 PM ---------- 6 hour anti-bump limit - Previous post was at 04:46 PM ----------
Don't quite understand??:hmmmm:
tom's
2,865
76
subang
Rav4 #CA2# model have both 1.8 1ZZ & 2.0 1AZ original... My Power enterprise turbo kit removed from mrs used set..that turbokit i'm selling at RM6500 with power fc for mrs
Supra_Fanatics
20,685
3,998
Any chance that you know how much improvement to performance if 1zz-fe added with MR-S turbo kit bro? Mind to share? :smile:
Guys n Gals,
Need some tech discussion here. I recently put the FICD on my VR4 and it has solved my engine mati problem. Now, the idling is very nice. But only after I run the car. What I meant is, if I want to off the engine to go down and buy something. When I come back, start the engine, the idling will be very low, and sometimes do mati engine.
But when I rev a bit, or continue to drive and on the air-cond, after 1-2 mins, it will be ok. What is going on?
Another issue is that...
