dkny
Viking tyre is to replace Sime tyre, which gona phase out.
Previously using Yokohama A drive. Not much difference I guess?
Yup, A-Drive are entry level tyre too...
I see. I know there is one more called A drive R1 too. How does that fare if lets say compare with C drive 2?
A-Drive R1 is entry level sports pattern tyre. In Yokohama Australia website they are called Affordable Handling upgrade, something like BS MY-01 being called a Sports Touring tyre.
Not to say whether good or bad, but just like entry level in Sports category. What I know they are made for economy so it is cheaper and durable, not so much into top notch performance. For that they have the S-Drive....
Oh! R1 I think comes in larger sizes too...
I will say C-drive 2 is in between A-Drive R1 and S-Drive, but then again what priorities? If for cornering I will say R1 better, comfort and grip C-Drive 2....
Thanks a lot for the information. This will help me next time.
S-Drive is very expensive, haha.
No problem, you are welcome.
S-Drive, if not mistaken comes in 15" minimum....14" tak dak.....![]()
Upgrade 15 bro. A lotttt cheap cheap ones.
Then got to pay for rims mah! unless source for 2nd hand ones.....
Tiggo now thinking of 17" because tyres size in 16" very little choices and expensive....![]()
Yah, second hand ma.
Fulamakkkkk. All 17 at home. Cilaka poison. Must ban your hse already. :hahaha:
ha! ha! saw my friends XV on 17", look damn good....
For me not poison but actual looking for right tyre at right price. Original tyre size only a handful to choose from, and downsize on rung also not many tyre choice....
DIT coming woh!.....hahahhahahhahhaa![]()
If put XV rims on Tiggo, don't know how it will look.
Have not check Tiggo PCD, maybe same then can search 2nd hand.....hahaha![]()
PCD is?
PCD is?
Pitch Circle Diameter is the correct name.....
Read Bolt Circle...
Wheel sizing - Wikipedia, the free encyclopedia
Anyway, check already is 114.3 x 5 holes. XV is 100 x 5 holes cannot fit.....![]()
Er, so there is no way to change this? So let's say my Wira is using 4 holes. So it is impossible for me to use a rim with 5 holes?
Can, got to spend more to convert the hub. But why do it, as they are many rimes with 4 holes, 5 holes, even now 8 holes and ten holes for both 100 and 114.3 PCD....![]()
Similar threads | |
