help..l2s problem..
Mar 4, 2014
seremban
My l2s engine have problem when I fill my fuel tank to full tank...after full tank I press oil until 5k rpm my car will just like fuel not come to engine..any 1 know what the problem?
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
better check.. i think its not becos of full tank of fuel.. maybe something else problem just about the rite time u fill full tank.. check ur fuel pump working properly or not then check ur plug cable and spark plug.
Supra_Fanatics
20,673
3,998
Supra_Fanatics
20,673
3,998
Yup, sometimes fuel filter clogged, fuel starvation and high revs.....
Don't remember changing mine before. Maybe my mira need to change then. Since u and I know the owner did not do what...:banghead:
Supra_Fanatics
20,673
3,998
Change lah! Your carb model, plastic fuel filter very cheap only...
Didn't know got that part ma LOL! Next time fuel tank also come with half cut mia. Will change fuel filter as well then. Going there on saturday. U coming?
Fuel tank is half cut rear. So unless you have 4WD for your model then they will bring in....
What you doing this time around? Radiator and fuel filter? Maybe only if free. Need him to check further on the exhaust manifold because seems is leaking from the gasket area...
Hello everyone, i am new to this forum and i am seeking guidance for my eterna gearbox.
I am currently running eterna TT auto gbox, and i wish to change it to manual. However, i am only able to find the complete manual gbox set minus the gear pedal and clutch pedal.:mad:
My questions here are:
1) is it possible to modify the VR4 or Evo 1-3 gear pedal and clutch pedal to fit to the manual gearbox?
2) If possible, can anyone recommend a workshop in Puchong/ Sri Kembangan/ Subang Jaya/ USJ...
