Basic Performance upgrade
stutzedward
3,416
561
Biao, so does it mean you are using Evo MAF sensor not rather than Airtrek's?
This was a hot topic for discussion in Airtreker.com last time before it was closed down. I also got to know from Ah Wah that it's not the same. Maybe those facts wasn't right then.
Yes, socket is always the same.
biao
348
24
perak / ipoh
yup, the foreman told me is dismantle from EVO. so now i using it.
but if cannot use, sure my car got problem now ,have issue come out. but now no any die and jerking.
so can you ask ah wah, after install will got what issue come out ?
or can you check the list of 4G63 spec, my friend ask me check and see, but i not so familiar on this.
just now i ask 1 friend, he suggest me find a airtrek MAF sensor to test the different.
got any member are from ipoh?
stutzedward
3,416
561
How much did you pay for the used MAF?
Well, if your car isn't facing any problem, I suggest you should not touch it anymore. Just drive as per normal.
stutzedward
3,416
561
CNY is like that la... once a year, no choice la...
But then, you better not clean the MAF again. Old car has problems, so it's unavoidable la.
stutzedward
3,416
561
Buy a new car if you hate all these problems. But with the same cost for a new car, you can only get a low-spec Myvi which is like 50whp... hahaha.
stutzedward
3,416
561
Would u wanna drive a car with 1.3 50whp chassis pushed to 100whp? Reminds me days of Wiralution. You can only do straight line speed and not able to stop on time. Even Passo turbo has about 120hp only.
now we have so many suspension tuners and as well as chassis bar/roll bar option....
we can go snaky way as well as fast on the straights :driver:
Here is something I come across, it might be common sense to people know how heat can build up in a car, but how hot? and how dangerous , people just assume is not lethal enough... however hope you can see clearly the danger of leaving any living thing in your car under the sun
