Timing belt question?!??!!
tangtang22
Dear all,
Need ur input as i plan to change my 4G93 timing belt.
My mechanic tells me need to change oil seal n the belt only, but not the tensioner as he says the tensioner no issue no kacau. Is that true?
Meanwhile, what brand to recommend? Tot of using back MMC, however the mechanic says now no more MMC and recommends Gates instead... Pening la, any brands u would recommend instead n where to get them??
thanks
the timing belt set consists of timing belt, tensioner & bearings. unless if u using power belt then u wont get the rest.
recommended to change all 3 mentioned stuffs to avoid complications in the future.
gates is good enuf, reasonable price & good quality, just beware of immitations, buy from reputable spare part shop.
So gates boleh pakai la.. Ok then, next question, where to get reputable spare parts shop? I went to a shop in seapark (wont name them) and i realise the gates packaging is different from others I have seen.. So i really need reputable spare part shops in PJ/Damansara area..
there is a hologram logo on the box together with their manufacturer sticker that requires u to sms your car model & mileage to them
for warranty.
where u staying? i always buy my parts near my hse, price is cheap with quality parts, always busy during the day.
I bought gates timing belt last time, warranty card all got except the hologram thing.
How ah? Already installed in car.
The print on the belt no defect like the one posted in the net.
One more thing i notice, the bearing is from GMB?
But why others from KOYO.?
Gates give koyo bearing only or i bought fake one?
Punk, likely u did not get the full Gates set.
I just realised that there are many packaging for gates timing belt n have to be careful when purchasing. Which is y i m seeking for referral for reputable auto parts shop here.. Hope those who know such places are willing to share : )
i get the full set, all the thing is actually inside the box.
jus the oil seal package and bearing is different.
1.Oil seal from corteco/NOK
2.Bearing is from GMB with green color seal.
after u buy, u check see if the bearing is from KOYO.
i cant remember but i bought dayco comes with koyo bearing, but when bought gates was not koyo bearing, it was another brand.
Yup, my mechanic always ask to change all even though no kacau and no noise but after so many k km mileage it should have worn. The problem is since already opening up might as well change, because if make noise later have to pay for labor to open up again. Some even change the water pump if this is located after timing belt...
Found this on the net.
Source from: Original & fake Timing belts
To provide a smooth engine operation, timing belts connect and manage related devices!
Genuine timing belts are durable because they are protected by fabric jackets! It offers high resistance against temperatures ranging from -40C to +140C.
When comparing an original timing belt with a fake, genuine has glossy white threads while fake has non-glossy black threads which is easily worn or torn! As a timing belt durability test result, genuine belt can handle 3,015kgf while fake handles only 2,044kgf.
It shows that genuine timing belt is 1.5 times stronger than fake one.
Genuine belt’s middle threads form even line distribution, but fake one’s threads form uneven distribution cause low durability.
Installing fake parts on vehicles may result in engine damage and premature breakdown.
Nice find! Although if we wanna see the fabric, must cut. HAHAHA
