Viking Tyres launched in Malaysia
Viking tyres from Norway have been launched into Malaysian market.
Owned by Continental and the tyres will be manufactured locally.
Two models CityTech CT-05 for smaller sizes and ProTech PT-05 for larger sizes
CT-05
PT-05
Supra_Fanatics
20,673
3,998
Totally different leh!....
Any good feedbacks on this tyres in Norway itself? At least better than local made or thai made tyres gua...but never seen the 1st one tyre pattern before.
Will be local made by Conti. To me should be entry and mid category...:driver:
Too much sipes....:smokin:
Supra_Fanatics
20,673
3,998
A lot of sipes indeed. Means is gonna be good on wet
When new should be okay. Not sure how deep the sipes are?
The best so far are the Michelin XM1, the sipes almost until tyre is bald...:driver:
---------- Post added at 12:09 PM ---------- 6 hour anti-bump limit - Previous post was at 12:06 PM ----------
I find it funny when I saw NCT 5 website says its good at wet.
NCT5 handles pretty well when new. However the sipes as mentioned wear off rather fast. Even at 20 to 30% wear almost half the sipes disappears. At 50% almost gone. You are using them, so you should know. I will try look up my old photos and post here for you.:driver:
---------- Post added at 12:28 PM ---------- 6 hour anti-bump limit - Previous post was at 12:09 PM ----------
Found them..
XM1 when new
XM1 when quite worn down
The sipes are still there except for the center line, which is already very impressive
Supra_Fanatics
20,673
3,998
Anyway, will never buy XM2 again. Is good as a daily use tyre but if u want to push it a bit harder. It cant take it.
Well what to expect from entry level or mid tyres.
Below 120km/h feel the tyre okay la...above that especially when come to a big curve, can feel that my rear is sliding a little. Lost traction.
Entry level, so treat it as entry level okay, not UHP......heh! heh!:driver:
---------- Post added at 12:37 PM ---------- 6 hour anti-bump limit - Previous post was at 12:33 PM ----------
Now on NCT5
This only slightly worn, and you can see the sipes already very shallow
This only probably 20% worn. Can see the middle sipes disappearing
This one can see the middle sipes gone and side ones starting to wear off too....
Supra_Fanatics
20,673
3,998
Ya seems NCT 5 not really have good feedbacks wor...yet is not cheap
OTR a lot. I guess everyone is not well educated then kena pushed to buy this tyres.
Camry, Accord all big cars using it.
Many came as OE fitting on the cars. Some consumers will change back since it is OE.....:banghead:
now my front tyre was on nct5....lesser grip than my prev hankook optimo...quite fast wearing too compared to the hankook also...might be better if use parada..nicer grip...last almost on similar pace/mileage :driver:
help me help me if anybody knew where to get forceum hexa size 185/60-15...plssss :adore:
Instead of the conventional way of changing the boot by removing the whole driveshaft, and then whacking out the CV joint, I used a simpler way to get the boot onto the cv joint. Note: This method should only be used if you are sure the grease inside is still clean and the CV joint is still in good condition.
Steps:
1. Identify which boot has torn (normally it is outer boot)...
