Review: Firestorm Ignition Coil Booster
for RPM below 3k the FS line was above, after that it moved under. hence it explained why ppl feel low end torque has improved. so for those who drive under 3k, it would be good for them
Over 3k RPM power lower the Original:confused::banghead:
Hmm that doesn't sound good then. But maybe have to be tested on a few more cars before drawing any conclusion.
That's probably how it helps more in auto cars...bringing up the lower torque. It is certainly good if we can have dyno charts to view..
l had it installed in my Saga Blm 2008 last year.
in city drive, this Firestorm does perform. car is more lively n engine noise is lowered.
but in higher speed during highway, the car seems like being shunt n lost of power.
in conclusion, it is good for car with low rpm or drive <120km/h.
tried on my nazaria, no feel.
Dear seller,
Please hand a pair to Izso for testing. He has been a reknown tester/mythbuster and DIYer in the forum. If your product is really good and can be verified by Izso, I belive that will build the brand image and generate a lot of confidence amongst forumers.
I do not doubt on the performance of this thing. For me, the prime concern about these ignition enhancers is "how long does the ignition coil lasts".
Thanks.
An installation in Izso's car would be some-what permanent, as it is unlike the usual plug and play installation. I doubt there are active seller in ZTH apart from peterlm. Hope that maybe he can provide a unit for testing..
I have my OEM spark plug cable at home that I'm willing to chop up. Not my best icables though, those are expensive and my current favorite.
:biggrin:
Speaking of testing, I'm gonna post up my vsafe fuel additive findings. Comes with dyno! Most expensive test of my life. RON97 included into the test too. 2 fillings sommore.
That is even better, right? Monopoly business in ZTH. If confident with the set performance, a good report will be very helpful for him....:driver:
The problem is the company name of this product is still unknown. I guess this really give a big disadvantage on customers' trust. Although this products and the sellers have been around for quite some time, it still lack of black and white.
Anybody here has been using this product for years? Any problem encountered so far?
mhmm. dyno proven on Inspira 1.8M
just curious, this is on WOT right?
any ideas about half throttle, closed loop?
but anyway if my noob understanding of WOT dyno charts are right, if the powerband changes like that, it probably means the air fuel ratio or the ignition timing has changed..
just my guess... [ super big spark takes longer time to generate thus the timing is retarded -or- the spark is super duper big that it burns so fast that the timing is advanced ]
thus kinda curious how most cars ecu will handle this over time
i.e. afraid it may work magnificently well for a short period of time till the ecu relearns and advances / retards certain parameters thus negating any gains
Ho ho ho... A Firestorm seller has offered to loan/give me a test unit for review. Gonna meet him next week to discuss.
:biggrin:
