blacktop check engine blinking.
kampret
Hi sifu,master friends and all toyota lovers, i need help...when i start my engine without air-con the check engine light will not blink but i will blink when i use the air-con.i stay at balakong..if anyone have a master mechanic for toyota please give me his details.
Thank you.
bro...help me please...if that is a big problem,i ll need to take note about that...but i didnt know what happen?some of my friend say wiring,some of them say trotthle body..pls give a a advice or any suggestion?
Hi Kampret
It won't be trrottle body problem... go kick your friend's ass for the fault advice :biggrin:
Did your aircon still running cool?
How does this problem happen? After service your aircon?
engine check normally due to the fault sensor. there are several sensor on your car. try to check with your car workshop.
Thank for the info bro and sifu...actually my aircond still running in good condition.is that problem related to my aircond?i have never service my aircond after change my engine.so do i need to go to the workshop to check my computer box or i need change something related to this problem?anyway thanks for your support..i appreciated that.
Hi there...
when you turn on the air con...did the RPM went below then 800 rpm and shoot up again back to normal...?
when i drive...it will happen suddenly if i used the aircond...and the rpm become 500..and it will be normal again if i turn off the aircond.it happen to you before?
Try retrieve the error code from the ECU.
If there is no code then please check what type of the ECU you are using (5sp - grey socket, 6sp - white socket).
If it is grey socket then most likely its the ECU problem.
Wong...not because of dirty TB aaaa ? clogged vacuum holes...
Yes a clog TB will cause the idling to drop to 500rpm when turning on the A/C
But it will not cause the check engine light to blink.
So far i can only link the blinking check engine light to ECU problem.
It mean, his car may have more than one problem...
Hye sifu and friends
ermmm....if you say like that, thats mean i need to change the ECU?or it related to wiring?my car got many problem?ermm...i need to send to workshop?
but for this 3 days i used my car....the check engine stop blinking.why?? i cant understand...it make me crazy:confused:.Last Monday i drived my car to Klang but its running smooth...but i afraid it just for a while and i afraid to used the car for long journey.
Bye the way thanks for your support and advice.
diagnose it so u can easily know which sensor is giving problem
so u can check the sensor itself, harness,connector, wiring etc.
if sometimes ON sometimes OFF, clean everything and plug it back then reset ecu.
if OFF permanent then solved, if still ON and wiring evetything is fine. sensor itself need replacement
bro ist this method working with toyota wish 05?
this mostly applied tro earlier batch car which OBD socket is not available
for wish, since there is OBDII port available, it much easier if u direct plug in OBDII scanner to pull the code
this mean cant do by ownself la....must by tools or send shop to check...ermmm
before this my car have a same problem.. but after clean throttle body. check engine stop blinking. but my car rpm timing above 1.5 and sometime my car engine off and check engine appear for a second. this problem happen to ur car kampret?
A thread every 60 seconds
