WHY Check engine light off? (blacktop 20v)
bus_3rd
81
1,508
Hello all..
want to ask everyone about mycar problem..
When i drive..nothing different happened i've seem..
2days ago i drive my corolla..ENGINE BLACKTOP 20V.
Suddenly mycar shutdown itself..
after that..i try to start but cannot..
the battery light is ok/on..all the power such as radio,lamp,wiper can on
then i look at my check engine light its OFF..
now im stuck with my car..
dunno what the problem :mad: :confused: :banghead:
HOPE SIFU2 CAN HELP ME :adore:
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
engine check light bulb KO perhaps...
try to open the meter cluster n replace or swap it first...
once done...run an engine diagnosis...
if no error code appeared...open up ur ECU ...follow your nose, smell if they any burned smell and look for any burned mark...
bus_3rd
81
1,508
check engine bulb KO?
i think if CE bulb KO..the engine still can be start..rite?
diagnosis?huhu..must towing my car to shop la..too far from city huhu..
if the ECU ok not burn..so what next step i should do?
---------- Post added at 12:48 PM ---------- 6 hour anti-bump limit - Previous post was at 11:42 AM ----------
UPDATE: finished checking myECU..nothing burned smell...board clean n clear..
so..what next must i check?
bus_3rd
81
1,508
cranking sound?
dont understandla chin..(tak faham la chin)
push on the switch just hear the starter n engine want to start only..like normal we start engine but doesnt start..
*sorry for english broken
Dayline668
1,810
492
1,683
did u check the fuse box..? did the engine oil light on when key on? just a guess...
bus_3rd
81
1,508
yup..engine oil light is on when key is on..
and before this engine oil light is also on..after engine start then the engine oil light is off..
FYI engine oil i change every month..
D7zul
2,697
848
Shah Alam
u should do this..
1. check fuse.. mayb burnt
2. open ur ECU & test it at a wshop.. or try other ECU on ur car
3. check ur spark plug
4. check fuel line..
hmmm.. what else? :hmmmm:
j_l200s
338
74
3,028
if engine can crank, all u need is fuel, spark and oxygen.
try checking the fuses, ecu, fuel pump, fuel regulator, spark plugs/cables, distributor, coil, ignitor...
bus_3rd
81
1,508
engine can crank..fuel half tank, spark ok, oxygen dunno..
but is it possible with that prob make the check engine off?
if error on any part the check engine will be tell like blink2 rite..thats tell something prob..
but this prob the check engine totally off..
is it possible the ECU KO already eventhough not burned on circuit?
j_l200s
338
74
3,028
Try using a wire a shorting the TE1 and E1 terminals in the "DIAGNOSIS" black box near the coil. this is to re-confirm if your bulb is KO or not. if it starts to blink then i think u better take your ECU for a checkup.... paging ECU sifuuuu
chinozie
3,429
170
5,163
Damansara
that's why I've told you to check the engine light bulb first...
once changed, from there you can check the check light n run diagnosis...
or else if bulb is working fine...still no engine light...most probably wiring problem...
where's your location...?
bus_3rd
81
1,508
im at kelantan
The dual-hinged doors on Tesla Model X is like a modern day sophisticated gullwing. For engineering enthusiasts, the Falcon Wing (what Tesla name it) door is indeed something to be appreciated.
I believe the Falcon doors are designed that way for easy access and to avoid the edge of the Model X's door from hitting another car or a wall at the car park for example.
If...
